Interfacing the Propeller to a Bioloid Dynamixel AX-12+
I can not find the documentation for interfacing the Propeller 3.3v pins to the 5.0v Bioloid Dynamixel AX-12+ servos.
Any help would be appreciated.
"It is not necessary to change. Survival is not mandatory."
- W. Edwards Deming
- W. Edwards Deming
or this thread http://forums.parallax.com/showthread.php?p=653117 might be useful.
Looks like inaki is the go-to guy on this subject.
Brian
uController.com - home of SpinStudio
PropNIC - Add ethernet ability to your Propeller!
SD card Adapter
IIRC the atmel chip running the AX-12+ and the CM-5 is a 3.3v part. I would guess that you could drive them at 3.3V (but I could be wrong). I'll be trying it myself soon.
I have been working on an AX-12 object and I finally made some headway. It was a bit tricky byte I got it working.
I need to do some work on the receiver though. As is, I can't add any more instructions without messing up the bit timing. I welcome any comments or suggestions.
I have a suggestion.....
When you get the AX-12 done, you can go ahead and write the object for the other Dynamixel servos.··· :-)
I've looked to buying some and doing the interface, but never have gotten around to it.
They are interfaced with RS485.
James L
James L
Partner/Designer
Lil Brother LLC (SMT Assembly Services)
But since you bring up this point, this object works with all the Dynamixels since the Dynamixels all use the same command structure. You'll simply need a serial to RS-485 converter check out Maxim and the Dyanmixel manuals.
I was joking, but I do appreciate the information.
I didn't realize the command structure was the same for the rs232 and rs485 systems.
If I get a chance, I'll look through your code and see if I can help.
James L
James L
Partner/Designer
receive_header test axmask,ina wc 'C is set if odd parity after AND
if_c jmp #receive 'if C is set jump to receive
should be
if_c jmp #receive_header 'if C is set jump to receive
I found an alternative method which works out nicely. It uses byte(4), length, in the response packet to get the remaining bytes of the packet. It only took 3 lines of assembly code and an extra long to do the trick.
1/23/2008 - Oops had a bug.
Post Edited (Mike G) : 1/24/2008 3:10:26 AM GMT
