RC-4 Relay Board - Available! — Parallax Forums
Lauren DavisLauren Davis Posts: 313
edited 2007-06-19 22:50 in Announcements
RC-4 Relay Board (#31204) - Available
······ attachment.php?attachmentid=47820
The RC-4 is a perfect companion to the Prop controller boards' versions 1& 2. If you need to control 110VAC loads, you can now do so safely with the Prop-1 or 2 and the RC-4. Three conductor cables (also available from Parallax) safely commute the low-voltage command signal to the solid state relay (SSR). Small but bright LEDs indicate which loads are "hot". The RC-4 board supports the popular Crydom D2W series of SSR. These relays can switch 2A @ up to 240 VAC, though it is recommended that you design your system to use 110VAC instead. Mounting holes accommodate #6 size screws to keep this board affixed securely. Large screw terminals accommodate up to #14 AWG wire. Always remember, voltages in excess of 60V can be lethal. Use every precaution to ensure safety. If you are unsure about what is safe and what might not be, just ask us. We are always happy to help.
For more information, or to purchase the RC-4, visit http://www.parallax.com/detail.asp?product_id=31204.
Lauren Davis
Marketing Manager
916-624-8333
ldavis@parallax.com
450 x 373 - 75K
