BS2 Universal Guitar Tuner Project Version 2.0 — Parallax Forums
TechnoRobboTechnoRobbo Posts: 323
edited 2011-01-23 19:38 in Robotics
The Background Story
Since I first posted this Project I have been working with JohnBF to allow this circuits to work with a wide base of microphones as well as electric guitars - the following circuits is the result of a series trials and reinventions.
All timings are BS2 specific but can be modified - I've included my spreadsheet In case any of you want to modify it.
The Circuit
The circuit creates·a super-amplified signal·that "clips" the wave into a square wave- the top and bottom half of 2 waves are summed·and sent to the BS2 for meausring with the pulsin command. To compensate for piezo pickups, a 1 meg resistor was added to ground. The speed of the BS2 worked against us since it was crucial that the wavelength had to be measured as a whole and not 2 parts (high and low).· I solved both those problems by adding a CD4017BE decade counter which summed the top half and bottom half of the wave. I also used the CD4017BE as a frequency divider allowing· the BS2 to measure higher frequencies and lower freq's more accurately.
JohnBF has been testing circuit mod after mod with me and is working on a propeller version using the same front end circuit.
The Software
The new code is faster and has excellent noise rejection. The code measures·a wavelength·and displays the·Note and the Tuning Position·on the LEDs'. The LED's Decimal point denotes a Sharp.· (Like any tuner it's best to use 12th fret·Harmonics - the notes have less transients and are more stable.)
The Parts List is a follows.
2 -·74HC595 Shift registers (Parallax)
1 - CD4017BE Decade Counter/Divider
1 - LM324 Quad Op Amp (Radio Shack)
1 -·7 Segment LED Number Block (Parallax)
1 - 10 LED Bar Display (Radio Shack 276-081)
18 - 1k Resistors
2 - 1 Meg Resistor
1·- 470 Ohm Resistor
1 - 1/4 inch Jack
Have Fun
TR
Post Edited (TechnoRobbo) : 5/6/2007 7:00:38 AM GMT
  • JohnBFJohnBF Posts: 107
    edited 2007-04-01 01:24
    TR,
    Hey, thanks for posting this - I've been wanting to put together a tuner for quite a while. Just happened to have all the parts lying around, so I wired one up on a Parallax Professional Development Board. Unfortunately I can't get it to recognize an incoming signal. I play an acoustic guitar, so I'm using the piezo transducer pickup I use with other tuners. Might it need a stronger or different kind of signal from an electric guitar pickup?
    /John
    edited 2007-04-01 17:10
    It didn't work with a dynamic mic either. The BS2 and the three chips are OK, so I must have messed up something in the wiring. I'll come back to it in a couple of days with a fresh eye. Thanks.
    /John
    edited 2007-04-02 02:26
    Good idea. The note variable stays at 0 and tunepos cycles between 0 and 1, so problem would seem to be right up front. I quadruple checked the wiring through the op am and I don't see a problem. So near yet so far. Thanks for all your help!
    /John
    2040 x 1540 - 556K
    edited 2007-04-02 02:28
    Oops. Wrong jpeg.
    3008 x 2000 - 520K
    edited 2007-04-02 23:15
    Sorry, the SX is just sitting in the slot but nothing is connected to any of its pins. I'm using a BS2, just above the top of the photo - but all the connections are to its pins. I did some more checking today and I'm stymied. The dynamic mic works, and the BS2 and the specific pins I'm using are all fine. I checked that all the resistors are the right value - wiring still looks OK. I'm sure I'm missing something obvious, but so far I don't see it.
    Well, maybe I'll try taking the SX out of its slot but I don't see how that could make a difference.
    /John
    edited 2007-04-02 23:22
    Here's a wider shot. And I took out the SX and it didn't change anything. Hmm....
    /John
    3008 x 2000 - 726K
    edited 2007-04-02 23:37
    Here's what I get from pin 7 of the LM324. Is that the right pin? It's not a square wave. Does this tell you anything?
    /John
    edited 2007-04-02 23:56
    And pin 8 is flat until I play a note and then I get a waveform that seems to vary with pitch, like this, for example.
    /John
    edited 2007-04-03 00:27
    I switched them. Nothing changed. /John
    edited 2007-04-03 00:56
    Success! It works. Well, still something a bit odd. At first when I switched the polarity of the jack nothing changed. Then I reattached the leads to the o'scope, and all of a sudden it worked. But it only works with the o'scope leads attached. Take them off, and it doesn't work any more.
    What could that mean? Oh well, when I show it off I'll just have to say, "Why is that instrument attached? Well, I'm still testing the parameters...".
    /John
    edited 2007-04-03 01:00
    Give me 10 minutes to get the camera out. I was just having so much fun playing with it. I love it! /John
    edited 2007-04-03 01:19
    Here's a couple of shots. /John
    3008 x 2000 - 644K
    3008 x 2000 - 693K
    edited 2007-04-03 02:27
    Thanks! I really appreciate your help. /John
    edited 2007-04-04 04:55
    Thanks. I'll report back tomorrow. /John
    edited 2007-04-04 16:39
    The schematic fix did it. It works great with either a dynamic mic or a piezo pickup, with no other circuitry.
    Now that the front end works, I'm thinking of playing around with more visually interesting ways of displaying the note and pitch, and perhaps switch to a propeller to broaden the possibilities. Should be fun.
    Thanks for sticking with this!
    /John
    edited 2007-04-07 01:13
    Quick feedback on the updates:
    With my equipment and setup, the new code is a win-win: faster and seems more accurate. The new circuit is more accurate using a dynamic mic, but it doesn't work at all with my piezo pickup. I'd like to stick with the piezo, so for now I'll keep the old circuit, and use the new code as the basis for exploring display ideas.
    By the way, one thing I realized as I experimented is that I really want to be able to display sharp and flat symbols. A serial LCD would be easy, but it maybe not fast enough. If so, I'll try driving a parallel LCD directly. Of course the propeller will drive a small video screen but that's probably overkill. Maybe print sharp and flat symbols on something clear and have LEDs light them.
    Looking forward to trying out any more tweaks you come up with!
    /John
    edited 2007-04-08 19:17
    Great. The technical explanation is above my head, but I will hold on to it - hopefully I will understand more as my study of electronics continues. I will try the the new schematic and let you know how it goes - I should have some more time this evening.
    In the meantime I'm using your April 4 schematic and April 6 code (I'm keeping track!).· I got an LCD display going, along with the LEDs. The LCD display does lag behind the LEDs by just a hair, but it's fast enough to be entirely usable - in fact the LCD makes it usable in a very natural way. If anyone is interested, attached is the code I added for the LCD, and a photo of my test setup.
    /John
    edited 2007-04-09 01:17
    OK, here's the results of my dining room table lab tests. The April 4 schematic still works best for me. Today's new schematic works, but not well. It most often jumps around without ever finding the note. This is true both for my piezo pickup and dynamic mic.
    I've watched what happens more closely with the April 4 schematic, which works quite well, but sometimes (like all tuners) has trouble finding the note. The dynamic mic seems to be slightly better with the lower note strings (4, 5, and 6) and the piezo is slightly better with the higher strings (1, 2, and 3). But either way it already works better than some of the cheaper commercial tuners I have and almost as good as my longstanding favorite, the Boss TU-12 in the photo above. Not bad! Still, I'd be happy try any new ideas you have.
    What about software? Kalman filters do a great job cutting through exactly the kind of noise coming in from the pickup. I have a friend in the industry, and he doesn't know any trade secrets, but he thinks Kalman filters, or similar routines are used in the better tuners. He doesn't actually know what Kalman filters are, but he's heard the term. No question a kalman filter requires too much processing power for even the fastest of the BS2s. But it should be possible on a propeller. There's a thread on the propeller forum from some people trying, or hoping someone comes up with a Kalman filter routine for the prop. I'm working on it too, but I have a long way to go.
    Or maybe there's something less sophisticated than a Kalman filter, but more robust than averaging five readings. Any thoughts about this?
    /John
    edited 2007-04-09 20:48
    Yes, the low pass filter is a definite improvement with the piezo. By the way, in my excitement about having fun with the technology, I completely forgot that I actually play five string banjo more than guitar. And I've never found a guitar tuner that works really well with a banjo. Before adding the low pass filter I tried the piezo with the banjo and it worked pretty well. When I added the filter it made a dramatic improvement - in fact it now works better than any tuner I've tried with the banjo. So you can bill it as a guitar-banjo tuner!
    I have no idea why this tuner works so well with a banjo, and others don't. The banjo notes are mostly within the same range as the guitar (the highest note on the banjo is the fifth string which is a g, two notes above the high e string on the guitar). The banjo has less sustain than an acoustic guitar, but maybe fewer overtones.
    I'd be happy to try any more ideas you have but in the meantime I'm also putting together the prop version. I had a little trouble figuring out how to drive an LCD with the prop, but that's solved. The prop should solve several problems. One is that I don't have to worry about the LCD slowing down the note-finding routines since the LCD driver can run in parallel. And for software enhancements there's more than ample variable space, floating point math and all.
    /John
  • TechnoRobboTechnoRobbo Posts: 323
    edited 2007-05-06 06:41
    The Software and Circuit Has been reworked to address the concerns raised by·JohnBF. The circuit is now Universal for electric and acoustic guitars. JohnBF and I have tested the system with a variety devices. Please look at the first entry in this post for the latest and greatest. My replies have been deleted so as not to confuse with older code and schematics.
    Have Fun
    TR
    Post Edited (TechnoRobbo) : 5/6/2007 6:50:22 AM GMT
  • BeeboDaMooseBeeboDaMoose Posts: 10
    Hi guys I'm Ed Electronics Engineering Tech
    I am trying to suppress the harmonics of the guitar string for this design..
    my plan so far is 2 part:
    analog agc and comparator circuit looking just below the top rail
    then looking for the greatest time that repeats
    using software to supress the harmonics
    this may involve a different tuner design
    I have worked out a design using a standard 32 khz clock crystal
    and an external counter
    do you think you design can handle the stamp doing SoftWare Supression
    or should I start my design in another thread ?
    12 bit external counter
    Note F T Count
    E2 82 Hz 0.01219 3994
    A2 110 Hz 0.00909 2978
    D3 147 Hz 0.00680 2228
    G3 196 Hz 0.00510 1671
    B3 247 Hz 0.00404 1323
    E4 330 Hz 0.00303 992
    32.768kH clock crystal T = .0000030517578125
    Ed
    344 x 232 - 852K
