Relay Circuit
I'm trying to control a solenoid valve·with a bs2 on the homework board.· The connections are detailed in the attached gif.
The relay (radio shack 275-240) has the following specs:
coil - 5vdc/89.3mA/56ohms
contact - 1A at 120vac/24vdc
The solenoid is 6-24vdc/19ohms.
My code is as follows:
' {$STAMP BS2}
' {$PBASIC 2.5}
HIGH 1
PAUSE 1000
LOW 1
END
I'm using a seperate 9v battery to power the solenoid.
When the solenoid is not connected everything works OK.· I can hear the relay click on and off.
When I connect the solenoid, the program continually cycles without ending.· There is a brief blink of the power indicator on the stamp board and it repeats the code.·
Any help would be greatly apprecited!
' {$STAMP BS2}
' {$PBASIC 2.5}
HIGH 1
PAUSE 1000
LOW 1
END
2) Some cross connection is causing the power to the Stamp to fluctuate and the Stamp is resetting. Check your circuit for shorts. If the solenoid is physically close to the relay, it may be inducing a current in the relay coil that is feeding into the +5V supply
I added a 1N4005 across the coil·and put 24" leads on the solenoid to move it further away from the board.
Just about have the pages worn out on the text you suggested [noparse]:)[/noparse]·
Still having the problem.
Spaced the components further apart on the board.·
Replaced the resistor, diode, transistor, and relay one at a time in case there was a bad component.
Still not working when the solenoid is connected.
Next I tried moved the connection to pin 1 and ran it through a pushbutton to Vdd.· Relay worked as expected with solenoid attached.
Any clue why I cannot get this to operate when suppling the 5v for the transistor through pin1 but it works fine when connected directly to 5v at Vdd through a push button?
Same result with this setup.
Tried turning the relay on and off with the following code
HIGH 1
PAUSE 1000
LOW 1
PAUSE 1000
HIGH 1
PAUSE 1000
LOW 1
PAUSE 1000
HIGH 1
PAUSE 1000
LOW 1
PAUSE 1000
END
The relay turns on, then off and then the stamp appears to freeze and a low voume high pitch tone can just barely be heard.
Tried connecting pin 1 of the ULN2003 to Vdd through a push button and·the relay and solenoid worked as expected when the button was pushed.
I'm stumped
edit:
you can try something like this (edit from original in red) (look at my cool MS paint skills
Post Edited (Unstable) : 1/20/2007 4:45:17 PM GMT
I've worked on this for the last 18 hours with about 2 hours sleep.· You have no idea how much I appreciate the help·
