Prop Tester
Tracy Allen tells me my Stamp Tester should work on the Propeller with the proper program, since the Prop pins are arranged in four groups of 8.· I have the RCtime and Timing objects but RCtime only reads one pin.· If someone could write me a program to test Pins 0-7, 8-15, 16-23 and
24-31, I would be happy to give them a Stamp Tester.· I would like for the program to to test the groups in succession when any key is pressed and I would like to the results to be displayed on my 13" TV.· My board has the RCA connector for the TV object, tied to pins 12-15 with 1 percent resistors like the Prop Demo board.
Am I asking too much?
Sid
Sid
Sid
OS-X: because making Unix user-friendly was easier than debugging Windows
Will you be able to help me - I am way over my head?· The directory for this program contains RCtime, Timing and TV objects.· I will add my pushbutton object.· I have started a top file to glue it all together, named Top File RCTime, but that is where I get lost.
Sid
Sid
Sid
