Propeller Chip 5V tolerant? — Parallax Forums
KibaloKibalo Posts: 9
edited 2006-05-24 05:21 in Propeller 1
is the propeller chip 5v tolerant on its inputs or do i need to use a voltage divider?
  • Beau SchwabeBeau Schwabe Posts: 6,547
    Kibalo,
    With 5V directly applied to an input on the Propeller, the VDD substrate diode will be stressed.
    The PN junction of the diode only wants to "see" a maximum of 0.4V More than this and you will
    prematurely shorten the life of the Propeller.
    To solve this, all you need is a current limiting resistor in series with the I/O. This in turn will form
    a "voltage divider" with the substrate diode.
    In most applications a 1K 3.3k resistor will work just fine limiting the current to 1.3mA 394uA from a 5V input.
    Where you might want to consider another option is if the input speed is very high. The I/O pins
    also exhibit a small capacitance which in conjunction with an input resistor form a low pass filter.
    In other words a very high frequency on the input "might" get filtered out and not seen by the Propeller.
    Refer to this previous discussion....
    http://forums.parallax.com/showthread.php?p=586894
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 5/24/2006 5:35:00 AM GMT
