The DC-16 Board is Available for Purchase — Parallax Forums
Lauren DavisLauren Davis Posts: 313
edited 2006-02-24 00:48 in Announcements
The DC-16 Board (#31216) is·available for purchase!
Is your prop or display long on processing power but falling short of DC outputs?·That’s where the DC-16 comes in.·Through a simple serial link the DC-16 allows the prop programmer to add 16 additional DC outputs to your project, and through its addressability, this can be extended to four DC-16 boards (for a total of 64 outputs) on a single serial control line.·The switched DC outputs are available at terminals that will accommodate up to 14-gauge wire making the connection of as many solenoids, low-voltage lamps, and small DC motors as you need.·The DC-16 is powered by 9 to 24 VDC and a three position power switch allows the use of this supply at the V+ terminal, or the option to use a second (isolated supply) to power devices controlled on the switched outputs.·
······························ attachment.php?attachmentid=40583
Sincerely,
Lauren Bares
Lauren Bares
Product Marketing Manager
Parallax Inc.
916-624-8333
lbares@parallax.com
450 x 373 - 80K
