Lm334 — Parallax Forums
Lm334
OrionOrion Posts: 236
edited 2005-03-12 00:25 in General Discussion
I need some guidance with the LM334.·
So far I have hooked up the LM as shown in NV #29 figure 29.3 http://www.parallax.com/dl/docs/cols/nv/vol1/col/nv29.pdf, I think at least.·
Here is the data sheet for the LM334 I am using http://www.st.com/stonline/books/pdf/docs/2157.pdf.
I am assuming the "TOP" of the chip means pins down.· With this setup, I'm reading around 4.02v across the 10k resistor.· If this were, .01v/deg then that would be 402K or 263.93F! I don't think so, this room is around 70F.·
So next I tried wiring it with "TOP" pins up.· This gave me around 2.88v or ~58F.· Still seems low but a lot closer to what I expect.
What am I doing wrong here?· Is my voltage => temp calculation wrong/wiring?
  • Beau SchwabeBeau Schwabe Posts: 6,547
    edited 2005-03-11 21:45
    Pins should be down.... It sounds like your LM334 might be rotated 180 deg.
    1 o \/   8
    2        7
    3        6
    4        5
    For proper pin orientation you should see a dimple or notch near the "top" of the IC.
    Note: The pinout of this chip is "keyed" so that 180 deg rotation should not dammage it.
    However your description implies an upside-down connection which effectively swaps
    V+ and ADJ. I'm not sure how this will impact the life of the chip.
    Beau Schwabe - Mask Designer III
    National Semiconductor Corporation
    (Communication Interface Division)
    500 Pinnacle Court, Suite 525
    Mail Stop GA1
    Norcross,GA 30071
  • OrionOrion Posts: 236
    edited 2005-03-11 22:09
    Beau Schwabe said...
    ·I'm not sure how this will impact the life of the chip.
    LOL!! Thats why I buy @ least·5 of any new IC.
    BTW I'm using the TO-92 package.· Both readings where taken on different new·IC's.
    Post Edited (Orion) : 3/11/2005 10:13:14 PM GMT
    edited 2005-03-11 22:46
    In that case you have reversed V+ and V-, looking at the schematic I don't see any
    current paths that should let the smoke out, but this could be a simplified schematic
    in which damage may be likely.
    The pins are a bit misleading, but judging from the schematic, Q2 might allow you
    to do a DIODE check with a Digital Volt Meter to determine the proper pin out.
    Q2's Base is connected to the ADJ or the ANODE of the B-E junction. Q2's Emitter
    is connected to the V- or the Cathode of the B-E junction. I would expect to see a
    value close to .6V on your meter across the ADJ and V- pins.
    Mail Stop GA1
    Norcross,GA 30071
    edited 2005-03-11 23:27
    I get .67 volts like you said, from what I assume is ADJ and V-. Which would seem to be backward from the data sheet, "TOP" being pins down? This is the only way I get any readings close to what they should be. Is this normal with a TO92, "Top" on the data sheet is pins looking up?
  • upand_at_themupand_at_them Posts: 61
    I use the LM335, which is the Celsius version.· And I use a 1K resistor with good results.· According to the datasheet you want less than 5mA bias current.· A 1K resistor will yield 2mA bias current at 25C.· I would think the LM334 behaves the same way.
    I have my resistor at the sensor end, sealed with the leads in heat shrink tubing.· I've also cut off the adjustment lead; the offset is a constant, so any calibration I need I do in the software.
    Here's where I got the images and information: http://web.mit.edu/rec/www/workshop/lm335.html
    Post Edited (upand_at_them) : 3/12/2005 12:28:41 AM GMT
    120 x 160 - 816B
    120 x 160 - 587B
