Which A/D Converter to use? — Parallax Forums
SofalogicSofalogic Posts: 49
edited 2005-02-21 18:23 in General Discussion
Hello all:
·· I have a project coming up that will require an A/D converter. The project will be monitoring small currents or voltages. Once I have dealt with the voltage readings I will obviously convert to digital.
··· What is a cheap, reliable and easy to incorporate into parallax structure A/D converter. Another question, is it converter or convertor?tongue.gif
Sofa
  • Robert SchwartzRobert Schwartz Posts: 141
    edited 2005-02-19 18:58
    How small voltages are you talking about? I just got a ADC0831 and it works nicely. Its converter :
    Post Edited (Robert Schwartz) : 2/21/2005 4:53:12 AM GMT
  • NewzedNewzed Posts: 2,503
    edited 2005-02-21 00:48
    I strongly suggest the TLC2543.· This is an 11-channel 12-bit converter that is very easy to interface to any of the Basic Stamps.· 12-bit means the ADC has 4095 counts, each count being worth 1.22 millivolts.· So that would be the limit of your resolution.
    Sid Weaver
    Do you have a Stamp Tester?
  • agentileagentile Posts: 101
    edited 2005-02-21 14:27
    I guess it depends on how much resolution you need.· For a "decent" resolution, I would also recommend the ADC0831.· It is an 8 bit serial·converter which is easily adjustable in span and range.· And they only use 3 pins from the BS2.
    AG··
  • SofalogicSofalogic Posts: 49
    edited 2005-02-21 17:59
    Thanks for the response so far gentlemen. I will be measuring a range between 30mV and 1 volt. I have an option to go as high as 2.5 volts with a specific sensor. I will decide which to use after some experimentation. I dont believe resolution is much of an issue as I am not recording small variations. Thanks so much for the help.
    Sofa
  • achilles03achilles03 Posts: 247
    The 11 channel ADC recommended above is kinda pricey.· Unless you're going to be measuring lots of inputs, I'd go with the 2-channel ADC on parallax's IC accessory page.· I got 2 of those and they work nicely.· 12-bit resolution too.
    Dave
