BS2 timing accuracy? — Parallax Forums
MatthewMatthew Posts: 200
edited 2005-01-13 15:22 in Learn with BlocklyProp
How accurate is the 'pause' command for the BS2? Is it as accurate as a 555 timer?
    edited 2005-01-10 00:58
    Nope, the PAUSE command in the BS2 is not very accurate. The 'clock' on a BS2 is based on a 'resonator', which are not very accurate -- may gain or lose minutes in a day. On the other hand, a 555 timer is REALLY inaccurate, so the BS2 Pause command is better than a 555.
    If you REALLY want accuracy, go with the 1302 with an external 32Khz crystal. This gives you seconds per day accuracy.
    And of course, there are 10 Parts Per Million crystal-based timers, but these take more power (10 mA).
  • MatthewMatthew Posts: 200
    edited 2005-01-10 04:27
    Okay, but it's consistent (and accurate) enough for a 60 second time period if I'm only looking at full second, right?
    edited 2005-01-10 16:11
    It should be. Again, accuracy is usually stated in how many seconds off it is. Your 60 seconds could be 58 or 62 seconds. You'd have to do an experiment to find out.
  • achilles03achilles03 Posts: 247
    edited 2005-01-12 14:17
    In regards to a 555 timer... your accuracy is a function of the capacitor and resistor tolerances (and temperature drift) that you use to setup the 555, correct?
    Dave
    edited 2005-01-13 05:36
    Yes, the assertion that a 60 second PAUSE with the BS2 could be as low as 58 seconds or as much as 62 seconds is way off base. That said, at the same temperature the behavior will be consistent, so you can tune your program accordingly.
    Jon Williams
    Dallas, TX· USA
    D'OH! I'm so sorry, Jon, I did not mean to be way off base.
    Just so people know, Jon is the guru with·Parallax.· Occasionally I get things wrong -- as in this case. I still recommend doing a test to find out just how accurate the PAUSE is -- I merely know it is insufficient to do a Time-Of-Day clock. More than that I should not say, as I have NOT done such a test myself.
