SPI bus and wire length?
How long can the wire connections be on a SPI bus? The reason I am
asking this is I want to interface to a MAX6674 from Maxim to a BS2
40P that is going to be 6 feet away or more with shielded, twisted
pair cable. Will this work or am I pushing this technology? Should I
use series termination on the SPI bus to slow the edges down to
minimize overshoot/undershoot? The MAX 6674 is going to be located as
close to the thermocouple as possible to improve it's accuracy.
Jason
  • 3 Comments sorted by Date Added Votes
    edited March 2002 Vote Up0Vote Down
    Jason,
    Since you are doing SPI with 6674 (I need to do the same in a near
    future) can you recommend a good explanation of SPI? In my case it
    should be simple two slaves (6674, and a DAC) single master project.
    Neither Scott's book, no Al's give any details. I looked at MAXIM
    site and have not found much either. Sorry to bother you.
    Thanks a million.
    Alex.
    I
    as
    > Jason
    SPI aka Microwire aka 3/4 wire bus. Consists of a serial data in line , serial
    data out
    line(may only have 1 of these), a clock line and a chip select. Not sure of the
    maximum clock speed. On the STAMP you use the Shiftin/out
    command(data,clock) along with chip select on an i/o pin.
    Motorola site should have specs.
