BS2, BS2SX, and EEPROM question
Hi All,
I'm working on a program using a BS2 and I've run out of EEPROM.
Now, I may be able to reduce the size of the program somewhat by
making it more efficient, but I don't think it will be enough. As I
see it, I may have two options, either add more external EEPROM for
the BS2, or use a BS2SX.
If I understand things correctly, the BS2SX can hold 8 programs
with 2048 bytes of EEPROM for each program.
I can break my program up into 6 sub programs quite easily, as
long as they can be integrated together and use common variables.
I'm quite new at this, and just getting to the point to where I
can write code for the BS2, but the added features of the SX make it
a bit intimidating for me. Can anyone advise me on this?
Robert
  • 13 Comments sorted by Date Added Votes
    edited September 2001 Vote Up0Vote Down
    Robert,
    The BS2SX sounds as if it will do the job for you. I think Parallax
    has an equiv of the BS2SX which runs at the same speed as the BS2
    which will alleviate the need to change various timing parameters.
    At http://www.phanderson.com/stamp/ I did a discussion of the BS2SX a
    number of years ago. Hopefully, it will be of some help to you.
    Peter H Anderson, http://www.phanderson.com
    > Thanks,
    > Robert
    Hi Peter,
    Your discussion is a big help. I have a BS2SX that I bought
    originally, but shelved in favor of the BS2 in the interests of the
    slightly easier learning curve. I'll dust it off and play around with
    it, to get a feel for how to utilize the extra EEPROM and scratchpad
    RAM.
    Thanks a bunch,
    Robert
    --- In basicstamps@y..., pha@p... wrote:
    > Robert,
    Parallax
    a
    > > Thanks,
    > > Robert
    Hi Robert,
    I'm currently using a BS2SX to control my central heating system.
    It's quite a big project, with a parallel LCD, 6-key keyboard, 3 DS1620
    thermometer chip, 4 LEDs, a buzzer, and 6 relays. All together would require
    31 I/O lines, and I do it with the 16 of the BS2-SX plus some hardware.
    I have a lot of messages to display, which are located on differents program
    banks of the BS2-SX.
    Of course, you can't read the EEPROM of one bank from another bank. But you
    can run different programs to use different bank's EEPROM.
    I use the "crossbank calls" and "global and local variables" techniques.
    Those techniques are described in an application note from EME Systems.
    Whit this, it's quite easy to "navigate" from one bank to the other.
    Let me know if you want to have more info.
    And don't get intimidated by the BS2-SX, it's just like a BIG (and fast !)
    BS2... :-)
    Phil.
    Subject: [noparse][[/noparse]basicstamps] BS2, BS2SX, and EEPROM question
    > Hi All,
    > Thanks,
    > Robert
    Hi Phil,
    Thanks for your words of encouragement. From the sounds of the
    complexity of your project, mine shouldn't present any problem for
    the SX.
    Right now, I'm still developing the sub programs, and have a
    nasty bug in one of them. When I call a particular subroutine at a
    particular point in the program, it resets the Stamp. This routine is
    called up at other points and works fine.
    I'll keep slugging.
    Robert
    --- In basicstamps@y..., "Philippe Derenne" <derennep@s...> wrote:
    > Hi Robert,
    DS1620
    would require
    hardware.
    differents program
    But you
    techniques.
    Systems.
    fast !)
    > BS2... :-)
    > Phil.
    > From: <robert_hiebert@s...>
    > > Hi All,
    EEPROM.
    I
    for
    programs
    as
    where I
    it
    > > Thanks,
    > > Robert
    Hi Robert,
    Check your gosub nesting level at the particular point.
    It should not exceed 4 which is the maximum number of nested
    gosubs allowed. Make a goto loop if it does, instead of a gosub.
    greetings peter
    Oorspronkelijk bericht
    Van: robert_hiebert@s... [noparse][[/noparse]mailto:robert_hiebert@s...]
    Verzonden: zondag 16 september 2001 16:00
    Aan: basicstamps@yahoogroups.com
    Onderwerp: [noparse][[/noparse]basicstamps] Re: BS2, BS2SX, and EEPROM question
    Hi Phil,
    the SX.
    I'll keep slugging.
    Robert
    > Hi Robert,
    DS1620
    would require
    hardware.
    differents program
    But you
    techniques.
    Systems.
    fast !)
    > BS2... :-)
    > Phil.
    > > Hi All,
    EEPROM.
    I
    for
    programs
    as
    where I
    it
    > > Thanks,
    > > Robert
    >Thanks,
    >Robert
    Hi Robert,
    I have some information on cross bank programming posted at
    http://www.emesystems.com/BS2SX.htm
    You might also want to check out a thread from earlier this summer
    where Peter Verkaik advanced the idea of creating a crossbank stack.
    I think the final result of that is to be found in the FAQ at
    http://www.al-williams.com/wd5gnr/stampfaq.htm
    -- regards,
    Tracy Allen
    mailto:tracy@e...
    Peter, you are brilliant !!
    I'm using a PAK IX in that particular subroutine, and it has 3
    subs of it's own. I saw that 4 nest maximum in the manual, but had no
    idea what the consequences might be. May be a bit of a challenge to
    keep the program size down and still maximize on subroutines.
    Just to add to the overall frustration level, when I went to try
    your suggestion, at first, none of my programs would respond
    properly. I tried all sorts of different programs with no luck, just
    when I was about to give up and pour myself a stiff one, I happened
    to pass my hand over the bread board, and lo and behold, things came
    to life!
    Well, so happpens my breadboard, which houses my Stamp and 3
    PAKs, as well as some circuits that make up a simulator for my
    project, are placed between my PC keyboard and monitor.
    Could it be that static electricity is another unrelated
    problem, and if so, what's the permenant fix? I'll have to be very
    carefull about static and noise related problems, as this is an
    automotive application.
    I moved the board around a bit, but it's back in it's original
    location, working fine, as I rewrite my program to fix the nesting
    problem.
    Again, Many thanks.
    Robert
    --- In basicstamps@y..., "Peter Verkaik" <peterverkaik@b...> wrote:
    > Hi Robert,
    > greetings peter
    > Aan: basicstamps@y...
    > Hi Phil,
    > the SX.
    is
    > I'll keep slugging.
    > Regards,
    > Robert
    > > Hi Robert,
    > DS1620
    > would require
    > hardware.
    > differents program
    bank.
    > But you
    > techniques.
    > Systems.
    other.
    > fast !)
    > > BS2... :-)
    > > Phil.
    > > > Hi All,
    > EEPROM.
    As
    > I
    > for
    > programs
    > as
    variables.
    > where I
    make
    > it
    > > > Thanks,
    > > > Robert
    > basicstamps-unsubscribe@y...
    Subject and
    Hi Robert,
    A general gosub nesting level workaround is described by Peter Anderson at
    http://www.phanderson.com/stamp/gosub.html
    Might be helpful if you don't want to rewrite your subroutines, apart from
    the
    return statement.
    regards peter
    Verzonden: zondag 16 september 2001 23:49
    to life!
    problem.
    Again, Many thanks.
    Robert
    Hi Robert,
    >problem.
    Radiation from a monitor might cause problems, however as your
    project 'came to life' as you passed your hand over the breadboard,
    it most likely is a loose connection, problably some ground connection.
    I know breadboard connections give way if heavily used.
    To shield your project from any radiation you can place the breadboard
    inside a metal case, that should help.
    regards peter
    Thanks Tracy,
    Excellent stuff! I printed them both and they're in my reference
    library.
    regards,
    Robert
    it
    > >Thanks,
    > >Robert
    > Hi Robert,
    stack.
    > -- regards,
    > Tracy Allen
    > mailto:tracy@e...
    Hi Peter,
    More great information! I printed that out too, and added it to
    my reference material.
    Thanks for the advice on radiation as well.
    Robert
    > Hi Robert,
    Anderson at
    apart from
    > the
    > return statement.
    > regards peter
    no
    try
    > to life!
    > problem.
    > Again, Many thanks.
    > Regards,
    > Robert
    Sent: Monday, September 17, 2001 10:29 AM
    Subject: RE: [noparse][[/noparse]basicstamps] Re: BS2, BS2SX, and EEPROM question
    I had the same problem because I used too thin wires...
    Phil.
