LCD on BS2SX
Hello
I have a BS2SX
I want to use an LCD serial 2X16
My problem is on the LCD panel I have
1 VSS it's ok
2 VDD it's ok
3 CS what I do with it
4 SID is it equivalent of SED
does I connect it to one ouput of my BS2SX
5 CLK what I do with it
6 SOD what I do with it
7 Power Supply for led + it's ok
8 Power Supply for led - it's ok
Do you have a small programm and a notice
Thank's
I hope you can help me
If you Know a web adress where I can improve my english free I am
very interest too
  • 2 Comments sorted by Date Added Votes
    edited November 2000 Vote Up0Vote Down
    --- In basicstamps@egroups.com, dreamtex@f... wrote:
    > Hello
    > I have a BS2SX
    I dont know what LCD you are using but I'll try and answer from
    previous experience
    > 1 VSS it's ok
    > 2 VDD it's ok
    This is probably a chip select pin. You make it high or low to enable
    the data to be sent to the LCD. Must be a unique pin in BS2SX.
    Probably serial input data
    you can probably connect it to the same pin as the output line with a
    1K resistor.
    This is the clock line. Needs another pin on BS2sx but can be shared
    by any other serial devices.
    Probably output
    > Thank's
    Try and get the data sheet for the display. It will explain it much
    better than I can.
    Andy
    > very interest too
