Triggering Circuit — Parallax Forums
Triggering Circuit
edited 2000-07-22 14:33 in General Discussion
Hi Gang
I have a small dilemma. I'm working on a project that runs a
routine but when the value of a pot changes in the circuit it drops out of
that routine and reads the new value of the pot using RCTIME. What I need
is to create a circuit that creates a trigger so the stamp knows the value
of the pot has changed. After it reads the new value it resets the trigger
and goes back to running the routine with the new value.
Any ideas?
Chuck Sieveking
DAT Services
    I take it you've already tried using an 'old x' value
    to track the previous value of the pot???
    If you have, then I'm not sure what good using up
    an extra stamp pin would do you. Seems like a lot
    of trouble to create a whole circuit for this purpose.
    Please advise if you have already tried freeing up
    variable space or NEED a hardware solution.
    --- In basicstamps@egroups.com, "Sieveking, Charles"
