RF Modem — Parallax Forums
RF Modem
edited 2000-07-20 16:45 in General Discussion
I would like to interface a modem to a stamp and UHF radio. I
need
only 1200 baud. Has anyone used a cermetek modem module or any
other type of modem?
Larry Licht
llicht@u...
    edited 2000-07-19 15:43
    > need
    It is a very common misconception that a normal modem can be
    connected to a radio and it will work. Nothing could be farther from
    the truth.
    Send data relaibly over RF is an *extremely* complicated
    undertaking -so much so that there are companies that have entire
    engineering departments working on products. In addition, most
    radios will need to be modified to properly deal with a data stream -
    and many -by virtue of their design for voice- do not modify well.
    You didn't mention your requirement (range, reliability factor etc),
    but you can probably get away with the modules that Parallax
    carries (their RF modems -not the Cermetek Kit). These are quite
    reliable over very short distances -but you should certainly
    implement some kind of error-checking algorithm if you need to rely
    on the data. You should note that this is not a reflection of the
    quality of the product, but rather the nature of the task at hand.
    Mark Hillier, VE6HVW
    President, HVW Technologies Inc.
    Canadian Distributors of Parallax Products and other Neat Stuff
    Tel: +403-730-8603 Fax: +403-730-8903
    http://www.hvwtech.com
    edited 2000-07-20 06:54
    CML makes ICs for radio data transmission at 1200/2400 baud, in formats from
    MPT1327 FSK, MSK, free binary format, etc.
    You can interface these modems to most radios, all you need is their
    discriminator or audio output, microphone input, and PTT line, just like any
    amateur radio TNC.
    ALL radios, wether commercial or not, designed for voice communications, can
    be used to send data. In the end, this data is FSK (frequency shift keying),
    which is no more than a sine wave extremely coherent. Speech is a wave just
    the same, just not sine or coherent. For example, normal 1200bps FSK
    occupies a bandwith of about 2kHz, which is less than human speech, which
    occupies around 3kHz (the basic components, high-fidelity like CD quality
    uses much larger bandwidths).
    This means that if you can send voice, you can send data. ALL radios also
    have a microphone and audio pads in their PCBs where you can solder leads to
    go to your modem and controller.
    All the best,
    Mensaje original
    > De: Mark Hillier [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=gq1xaYXjnf0C-0Y5ovDbujoGBzsiCIg5BPeFHJ7TnX8XThvgxxQX3_gmPI6r7IV2cQ96ZW5L]Mark@H...[/url
    > Enviado el: mi
    edited 2000-07-20 13:46
    I'd have to agree with Mike here; in fact, doing it without a modem is what is
    difficult, engineering intensive, and probably limited to very short distances
    for reasonable reliability. Adding FSK modems to a cheap set of vhf/uhf
    transmitters is complex but very do'able if you do your homework; its the FCC
    you need to consider, walkie-talkie, CB,and FRS ( all the cheap transceiver
    sources(g) ) have voice only restrictions I believe...Even the frequencies
    allocated to data transmission have duty cycle restrictions and lots of other
    complex rules that take all the fun out of it. However, 'under-the-radar' as a
    goof, this is almost the perfect 'hack' project ( in the constructive sense of
    the word! ) Investigate the amateur packet radio world for plenty of background
    information. I say...go for it, sounds like fun!
    Bill Mrozinski
    Miguel Puchol wrote:
    > Hi,
    > amateur radio TNC.
    > All the best,
    > Mike
    Mensaje original
    > > De: Mark Hillier [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-8N2tPhSXKzsRTcQ6SEPfm0B1kpCtImj3F4-PL38YxGaGqfo6x-JNke2pdZ3xT2CqAntyZV_fz2xLgc]Mark@H...[/url
    > > Enviado el: mi
    Along these lines (FSK modem chips) Byon Garrabrant has a PIC project which
    replaces the TNC in an APRS tracker. It's quite ingenious. The whole thing
    including the .hex file is up at:
    http://www.byonics.com/tinytrak/index.html
    Another PIC based FSK modem is here:
    http://www.tfs.net/~petek/projects.html
    Couldn't find any strictly basic stamp examples. You could likely do it
    with a stamp, but only at a relatively low baud rate...
    Cheers, Duncan
