Altimeter — Parallax Forums
Altimeter
edited 2000-07-14 22:45 in General Discussion
I just thought I would let everyone know that i finished my Basic Stamp
pocket altimeter. I updated my page with code, schematic, pcb layout and
pictures of my new altimeter.
The one major problem i had to overcome was the equation for calculating
altitude. It is huge and has logs and anti logs. I first decided use a PAK
II for the calculations but when I decide to make a smaller version of my
altimeter there was no room.
Then I found out about linearization, and i got great result. Linearization
is made possible because the stamp is capable of linear math. Athough
implementing linearization takes quite a bit of code because you need many
linear equation it worked out nicely.
My altimeter has the following functions:
current pressure/altitude, max/min altitude, record altitude to a EEPROM
every second, display altitude data stored on EEPROM, and two calibrating
function manual and auto. The next version of the software i hope to have
ascent and decent rates.
If you interested you can check it out at
http://geocities.com/SiliconValley/Orchard/6633/altimeter.html
Shaun
________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
    edited 2000-07-14 04:42
    Hi Shaun,
    Just as a matter of curiosity, what would have been your (and others)
    reactions to a surface mount PAK-II? We supply surface mount parts on
    special order now (which requires quite a few parts to be worthwhile).
    However, if there was enough demand, we might make them a stock item.
    Comments?
    Al Williams
    AWC
    * Interface a PS/2 keyboard to your Stamp or other microcontroller:
    http://www.al-williams.com/awce/pak6.htm
    > From: Shaun Wilson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_QhQ_ecFZ1feqU1RcRQWEcYir7RF6fO61O8uP1xyj7QkaVUccKChWt20YvVwJd2YA1aXxbptpX0KReZIIFXzmBs]shaunwilson@h...[/url
    > Sent: Thursday, July 13, 2000 6:49 PM
    > To: basicstamps@egroups.com
    > Subject: [noparse][[/noparse]basicstamps] Altimeter
    > use a PAK
    > Linearization
    > need many
    > Shaun
    edited 2000-07-14 13:45
    You did a great job.
    I did this several years ago to log alt and airspeed on model airplane
    I guess since I selected a range of 0 to 3000 feet it was much easier
    I used a similar baro sensor but at that time onboard signal conditioning
    was not available. I used a double 741 (x1000) for op-amp
    one was for alt the other was for dynamic pressure. I made measurements at
    about 300 ft intervals and used a curve fitting program to give me a
    polynomial so that I constructed my own calibration curve. The linear
    transducer was very good. I believe that the linear model was not much
    different that the 4th power polynomial. Did similar with dynamic ram
    pressure to airspeed.
    I achieved accuracy of 2 ft and .1 mph
    I also simulated conditions with water u-tube manometer
    I used a very clumsy 80C32 compared to the one chip computers we have now.
    good luck
    Richard
    To: <basicstamps@egroups.com>
    Linearization
    > Shaun
    Shaun,
    You did an excellent job in building and presenting your altimeter. I
    found it to be very helpful when I built my recording
    altimeter/speedometer for by bicycle. With it I can log altitude and
    speed every 36ft for rides up to 60miles. One advantage I have is
    that I download the data after the ride and have Excel do all the
    calibrations, calculations and graphing.
    With serial eeproms being cheap, small and easy to use did you
    consider creating a lookup table to convert to altitude. With a 64k
    eeprom you could store all the altitudes that correspond to the 4,000
    discrete levels you can achieve with your ADC. I assume you would
    have to make some adjustment for the current pressure.
    Hopefully when I get my altimeter/speedometer beyond the solderless
    breadboard it is on now, I'll be able to present like you did with
    your altimeter.
    Jim Spencer
