New to this!! — Parallax Forums
New to this!!
edited 2000-06-30 18:29 in General Discussion
I am trying to write a part of a program that accepts keypresses from
a 3x4 keypad and when it does it puts out what was pressed on a Scott
Edwards LCD. The way I am doing the keys is by connecting all of the
buttons to 5 volts and the other side of the button(whether it be in
a certain row or column) is connected to an input on a BS2 and a pull
down resistor. My problem is this: In my software, I labeled each
button as a variable and then declared the buttons as the and of two
pins. Like this: BTN1 VAR BIT BTN1 = IN0 & IN4. I do this
according to the matrix. I put all of the declarations in a main
loop and then I do an if statement that will branch if a certain
button is pressed. It seems that when I go to another part of the
program and check the same key, it doesn't recongnize the definition
BTN1 = IN0 & IN4. I verified this using debug where I got in0 and
in4 as being 1 when the button was pressed but btn1 itself stayed 0.
Do I need to keep declaring what btn1 is in each place that I use it
or is there another way around this. It also doesn't see that
declaration if I put it outside the main loop in the beginning. Any
help will be much appreciated! Thanks a lot!!
Jeremy
    edited 2000-06-30 12:55
    See the list of stamp applications via parallax website. No 157 has a keypad
    system you may be interesetd in.
    To: <basicstamps@egroups.com>
    Sent: Friday, June 30, 2000 1:40 AM
    Subject: [noparse][[/noparse]basicstamps] New to this!!
    > Jeremy
    Chris,
    Thanks a lot for the advice. I hooked up the circuit and it
    works pretty good. The only problem is that glitches occur when the
    button is first pressed. Do you have this same problem? Sometimes I
    will hit one key and it makes it out as some other key. When I debug
    the RCTime result, and press a button, you can see that the first
    number is always a random number that isn't the expected value.
    Please let me know! Thanks again!!
    Jeremy
    a keypad
    > From: Jeremy Gassmann <gassmajd@e...>
    from
    Scott
    the
    in
    pull
    each
    two
    this
    definition
    0.
    it
    Any
    > > Jeremy
