7805? — Parallax Forums
7805?
edited 2000-06-27 20:54 in General Discussion
I noticed in the boe-bot docs from parallax that they replace the old standby
7805 for a different 5v regulator..
Is there any reason why I couldn't still use one if I separate the power to the
stamp and to the servos?
Sean
    edited 2000-06-27 19:24
    That is the way I am doing it - so no I don't think there is a reason.
    richard
    To: <basicstamps@egroups.com>
    Sent: Tuesday, June 27, 2000 12:26 PM
    Subject: [noparse][[/noparse]basicstamps] 7805?
    standby 7805 for a different 5v regulator..
    to the stamp and to the servos?
    > Thanks
    > Sean
    To my knowledge, the reason for the new regulator is that it is a LDO (low
    drop out) variety. The original BOE used a 9V battery. The 7805 needs
    something like 7V+ to give 5V out. The BOE bot uses 4AA cells 4x1.5 = 6V.
    This isn't enough to reliably drive the 7805 and even less if the batteries
    weaken. The LDO part only needs a hair more than 5V.
    Al Williams
    AWC
    * Pulse input and output with the PAK-VII and PAK-VIII...
    http://www.al-williams.com/awce
    > From: Sean Conlon [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XqDoh3vEC9-e0nyJpEpAL5DUkbwdfGJzSaU-T3UtutCnO3LjEYPsyROyGzSCy45_NydFoo1jbZ5xFi8rrO50bP4]gnomish1@p...[/url
    > To: basicstamps@egroups.com
    > old standby 7805 for a different 5v regulator..
    > the power to the stamp and to the servos?
    > Thanks
    > Sean
