h bridge — Parallax Forums
h bridge
edited 2000-05-21 16:16 in General Discussion
I'm looking for schematics about h bridges. Can you help-me?
Thanks!
Fabiano Bovo, from Brazil.
_____________________________________________________________
http://www.zipmail.com.br O e-mail que vai aonde voc
    edited 2000-05-20 07:24
    At 03:17 AM 5/20/00 -0300, Fabiano Bovo promulgated:
    >Thanks!
    edited 2000-05-20 14:35
    Fabiano! Your alive. How come you've never replied to my mail? Anyway, I
    know that www.beam-online.com has a circuit or two for a 6 transistor
    H-Bridge. Maybe I'll get around to doing an article on it. Have you seen the
    new webpage? www.gorobotics.net
    -William
    To: <basicstamps@egroups.com>
    Sent: Saturday, May 20, 2000 2:17 AM
    Subject: [noparse][[/noparse]basicstamps] h bridge
    Thanks!
    edited 2000-05-20 17:43
    An H bridge is very simple, though somewhat difficult to show over email.
    You need 4 transistors, and an inverter. Depending on the motor you may need
    current limiting resistors.
    1. You have your input for direction - tie this to the base of two
    transistors.
    2. Tie the collector of one of these to Vcc and the emitter to the positive
    side of the motor for forward operation.
    3. Tie the collector of the other to the negative side of the motor for
    forward operation and the emitter to ground.
    4. Now, also connect your input for direction to an inverter. Run the output
    of that inverter to the base of the remaining two transistors.
    side of the motor for reverse operation.
    reverse operation and the emitter to ground.
    I'd try ASCII Art but I use a proportional font and I suspect you do too.
    I also assume you use NPN transistors.
    So:
    Transistor 1: Base to Input, Collector to Vcc, Emitter to + on motor.
    Transistor 2: Base to Input, Collector to - on motor, Emitter to Ground.
    Inverter: Input to Direction Input, Output to Transistor 3 & 4's base.
    Transistor 3: Base to Inverter Output, Collector to Ground, Emitter to +
    on motor.
    Transistor 4: Base to Inverter Output, Collector to - on motor, Emitter
    to Vcc.
    Where + and - are both for forward operation.
    Hopefully this will help you.
    edited 2000-05-20 18:37
    Two very good links:
    http://www.cadvision.com/blanchas/hexfet/
    http://www.us-epanorama.net/motorcontrol.html
    ACJacques
    > Thanks!
    well boys and girls, if you want the best exploitation and very usable
    circuits, go to the links in this guy's web site.
    the explanations are excellent with a little humor (fuse test mode) and very
    elegant and simple diagrams.
    if one of these doesn't work for you, your probably in the wrong
    (hobby/business).
    no offense intended, but this is really good stuff.
    Norm & Monda
    Cozy MK IV #202
    Ford V-6 Powered
    Sent: Saturday, May 20, 2000 1:37 PM
    Subject: Re: [noparse][[/noparse]basicstamps] h bridge
    > ACJacques
    > > Thanks!
