electrical design basics, 101: button, switch? — Parallax Forums
edited 2000-04-30 05:08 in General Discussion
Is it possible to use a single pole single throw slide switch to make a stamp
pin either hi or lo without wasting a lot of electricity? I'm trying to figure
out how to use hardware to set a variable in code to either a "1" or a "0".
ie: PIN 01 --->switch---->10K resistor--->ground
does the resistor prevent free drain of juice from the battery yet still allow
the stamp to tell whether the switch is "on" or "off"??
    edited 2000-04-29 19:01
    +5 VDC
    10K
    GRD -- SW
    To Stamp Input
    When SW is open the Stamp sees +5 VDC through the 10K. When SW is closed,
    the Stamp sees ground.
    The 10K may be anything. I would suggest in the range of 1K to 100K.
    When the SW is open the drain is limited to the leakage into the Stamp (on
    the order of uA). When closed to ground it is 5V / R or 0.5 mA if using a
    10K resistor.
    Peter H. Anderson, Morgan State University
    pha@p..., http://www.phanderson.com/stamp/
    To: basicstamps@egroups.com <basicstamps@egroups.com>
    Date: Saturday, April 29, 2000 10:29 AM
    Subject: [noparse][[/noparse]basicstamps] electrical design basics, 101: button, switch?
    :Is it possible to use a single pole single throw slide switch to make a
    stamp
    [noparse]:p[/noparse]in either hi or lo without wasting a lot of electricity? I'm trying to
    figure
    [noparse]:o[/noparse]ut how to use hardware to set a variable in code to either a "1" or a "0".
    [noparse]:ie:[/noparse] PIN 01 --->switch---->10K resistor--->ground
    :does the resistor prevent free drain of juice from the battery yet still
    allow
    :the stamp to tell whether the switch is "on" or "off"??
    edited 2000-04-29 20:40
    >figure
    Yes - you can but it takes a second pin. This pin can be any other pin
    used somewhere else in your circuit.
    One of my projects does exactly this. I have a pin that is used to drive
    another part of the circuit and I don't care what the state of that pin is
    when the circuit is sleeping. I take a 10k resistor from that pin to the
    switch I want to look at, then another 10k resistor from the switch to the
    input pin on the PIC. The other side of the switch is grounded. To read
    the switch, I wait until the software has driven the output pin is HI, wait
    a short time, then read the input pin to see if the switch is HI or LO. I
    save that state in memory. When its time to put the whole project to
    sleep, I simply make the output pin HI or LO to match the state of the last
    measured switch state. Bingo - no current drain from the resistor.
    Because I use the 'wake up on change' feature on the PIC, the pic wakes up
    as soon as the switch is changed.
    dwayne
    Dwayne Reid <dwayner@p...>
    Trinity Electronics Systems Ltd Edmonton, AB, CANADA
    (780) 489-3199 voice (780) 487-6397 fax
    Celebrating 16 years of Engineering Innovation (1984 - 2000)
    Do NOT send unsolicited commercial email to this email address.
    This message neither grants consent to receive unsolicited
    commercial email nor is intended to solicit commercial email.
    edited 2000-04-30 01:54
    most excellent, thanks very much!
    "Peter H. Anderson" wrote:
    > +5 VDC
    > 10K
    > GRD -- SW
    To Stamp Input
    > 10K resistor.
    ARC in Lago Vista, TX
    See you next week a little further up the creek. - Early Alaskan goldminers
    parting words after meeting.
    edited 2000-04-30 02:36
    Dwayne - that sound you hear is that of most of your method shooting right over
    my
    head [noparse]:)[/noparse] If it works as I think it does, it's darn clever. (I'm studying it)
    What is the "PIC" ? I'm guessing that it is another name for the the basic
    stamp
    assembly, so that the "input pin on the PIC" for example, would on my system, be
    one of my two existing button switch pins (say, Pin 01). The "output pin that
    is
    driven to HI by software" in your message would be the other pin that the new
    slide
    switch is attached to (say Pin 05), that I would define as an output pin?
    If I understand your message/setup, when the button switch is pushed, you know
    it(Pin 01) has just gone high. The software then checks the state of Pin 05,
    and
    if the slide switch was in the on position then pin 05 goes high also. I'd then
    set
    my variable = "1". If pin 05 doesn't go high, then set variable = "2".
    I don't think I've quite gotten it right, for some reason. Am I even close?
    > dwayne
    "Let's face the obvious. Yesterday we were nerds. Today we're the cognitive
    elite.
    Let's conquer." - Chester G. Edwards
    edited 2000-04-30 05:03
    >over my
    Sorry. I thought that you were asking for a zero power method of reading a
    SPST slide switch. If that is not what you need, the method that Peter
    Anderson is easier and better. But: I would add a series resistor between
    the switch and the input pin. In other words, there are 2 resistors going
    to the switch - one is the pullup and the other is the ESD protect resistor
    actually feeding the input.
    >basic stamp
    >system, be
    >that is
    >new slide
    Yep - the PIC is the actual processor on the stamp module. Its what I do
    all my designs with (I've helped others troubleshoot stamp based designs
    but don't use them myself. Just too expensive.).
    You have it close. Usually, the output pin is being used to drive some
    other portion of the circuit. When I set that pin HI (as required for THAT
    part of the code / circuit), I know that a short time later, I can read the
    switch. In other words, I can't read the switch until I know that the
    output pin with the resistor is HI.
    The advantage of this is that I can turn off the output pin when I want to
    power down. Then the pullup resistor does not consume any power. In my
    case, I set that output pin to match the state of the switch so that the
    resistor does not have any voltage across it - the pin might be HI or
    LO. Then, if the switch is changed while the processor is sleeping, the
    change in state wakes the processor.
    dwayne
    I have a simple combination lock toy that has six "tac" pushbutton
    switches. All my pins except pos, tied via a 10K resistor to ground. One
    side of the pushbutton goes to a pin, (7 switches, to pin 0 thru pin 6) the
    other side goes to the pos. Pushing a switch makes the pin a 1, releasing
    the switch makes the pin a 0. My code uses "if pin1 =0 and.... thru pin6 =0
    then loop" Thus it sits in a loop until a switch is pushed. However with
    many "if and" statements I determing what switches have to be pushed "in
    order", to make something occur on pin 7. Thus the right combination must
    be used to make a happening on pin 7. Even with only a 4 combination of
    switches many people have tried and not hit the right combo. I also did one
    with 6 different numbers in order to activate pin 7. Lotsa fun....... ==Mac==
    figure
    allow
