ADC help — Parallax Forums
ADC help
edited 2000-04-27 17:11 in General Discussion
I am trying to interface my BS2 with TI's tlc2541 ADC.
http://www.ti.com/sc/docs/products/analog/tlv2541.html
I don't quite understand the function of the SCLK pin. Is this an
external input, or a reference that the converter provides? If it is
external, do I need to provide some sort of oscillator or can I just
toggle one pin high and low?
Finally, does anyone know of any sites out there that discuss ADC
design? I haven't had much luck finding anything useful yet...
Chris
www.MesoSystems.com
    SCLK ("serial clock") is provided by the BS2 SERIN command:
    low ADcs ' select chip on CS\
    shiftin sdo,sclk,msbpre,[noparse][[/noparse]result\12] ' get result, 12 bits
    high ADcs
    The shiftin command provides exactly 12 clock pulses and the tlc2541 data
    appears on its sdo line in 12 steps in sychk.
    Most manufacturers provide application notes that go in detail into the
    particular technology that they use in their chips. Search their sites.
    If you want a tutorial that starts from the basics with the Stamp, check
    out <http://www.stampsinclass.com/downloads.htm> and scroll down to "Basic
    Analog and Digital Experiments".
    -- Tracy Allen
    Electronically Monitored Ecosystems
    http://www.emesystems.com
