Photo Sensors, Bad pins, and PC connection — Parallax Forums
edited 2000-04-24 15:52 in General Discussion
I'm using three cadmiun sulfide photo conductive cells to move 2
steppers. How can i get a value from each cell to compare to the
other
values of the other cells? Can i use RCTIME and asign a value to a
varible? Is there any A/D conversion that needs to be done?
I let someone do a little testing with my stamp and i think he may of
fired two pins. I tell them to output to an LED and nothing happens.
Is there any other way i can tell?
Last question:
After i hit the run button on the Stamp II program, the STamp should
then work indepently. But if i dissconnect the serial cable from the
stamp everything stops and is shut down, and i can't get the stamp to
respond. I don't get it.
If anyone can help me with anything i would greatly appreciate it!!
-Paul
