FSK Modems — Parallax Forums
FSK Modems
edited 2000-04-03 09:05 in General Discussion
Anyone have experience building their own (FSK) modems? I am trying to
expand a project of mine to include real-time data, and need a long distance
(~.5mi) unidirectional data stream. I have found an FM transmitter with
sufficient range, checked with the FCC (eductional research (read: science
fair project that I am expanding for the next level of
competition)--exempt!!), and hacked a walkman for a receiver. I have
attempted to use SEROUT from a BS1 to on/off modulate a 555 or two to
generate the data stream. The sticking point is demodulating the data. I
tried a 567 (too slow), and am now fiddling with a XR2211 to no avail. Any
other ideas? This is a data collection package for remotely-controlled
gliders , so size, weight, and cost are issues. Thanks very much,
Corsair000@a...
    edited 2000-04-02 21:07
    Okay, here's an idea or two...
    Lots of interface circuits to use audio cassette recorders for data storage
    were published before floppy drives got cheap. A search of periodicals in
    the 70s and early 80s should turn up something. As I recall, Robert
    Suding's interface was well accepted. It may have appeared in Byte or Dr.
    Dobb's Journal. One of 'em also appears in Don Lancaster's CMOS Cookbook
    (the Bit-Boffer).
    Use an LM2917 to convert your frequency to voltage, then use a simple
    comparator to get binary output. The 4046 PLL chip also does F->V
    conversion, and it's very well described in Don's book!
    Run your audio through a simple (L/C) low-pass filter and then rectify it.
    You get a DC voltage that's a strong (inverse) function of frequency if
    your audio frequencies lie on the cutoff slope. A comparator recovers data.
    Use a comparator or clipper to convert audio to logic levels and trigger a
    timer with it. The timer generates fixed-width pulses of width less than
    your minimum audio cycle time. Integrate the pulses with a simple R/C
    network. A comparator recovers your data. Or, you could use the pulse width
    measurement capability in a microcontroller at your receiving site, to
    deduce data directly from clipped audio...
    If you switch to a BS2, and speed isn't a big issue, you could use the
    DTMFOUT instruction for transmitting, then use a simple DTMF receiver chip
    to recover your data. There's a list of DTMF RX chips here:
    http://www.ee.washington.edu/eeca/text/DTMF.html.
    You might also find this link interesting:
    http://bart.us.es/~melus/gwlhw06.html but low-cost single-chip modems seem
    real hard to find lately. This one might actually be available:
    http://www.zilog.com/newprod/z02215.html.
    Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
    Manufacturer of the famous BOB-II Serial Video Text Display Module!
    edited 2000-04-02 21:17
    At 01:37 PM 4/2/00 EDT, Corsair000@a... promulgated:
    Grab a couple of 2400/4800/9600 baud external modems from the Salvation
    Army or
    some flea market/swap meet. Rip them apart, and have at it.
    >Corsair000@a...
    >eGroups.com Home: http://www.egroups.com/group/basicstamps/
    >http://www.egroups.com - Simplifying group communications
    edited 2000-04-03 03:21
    If you have the capability or care to expand your pic experience, visit the
    Scenix.com website and the source code to create a basic FSK modem with an SX
    chip is available. Sxtech.com is also a great place to go for further sx
    programming information. This is also the basis of ham packet radio and surfing
    on that topic will provide much info on the various ways of wireless
    transmission of data via modem. I am planning to try and send a GPS NMEA data
    stream this way in a project to be started soon. Check the following link for
    ham packet radio information and good luck!
    http://www.tapr.org/index.html
    Bill Mrozinski - DCS
    > Corsair000@a...
    edited 2000-04-03 08:11
    Look here for a PIC based FSK modem design:
    http://www.tfs.net/~petek/telemetry/index.html
    Duncan
    At 03:11 AM 4/3/00 -0400, orthner@s... promulgated:
    >Duncan
    Thanks Ducan -
    You may want to check these guys out:
    http://www.americaii.com/
    as a source for the TCM3105 chips, and perhaps pass it on to the author of
    the
    website. Findchips.com located than, and would indicate that they have 1000
    in
    stock. Certainly only direct inquiry would confim that.
    Bruce
