Altimeter sensor — Parallax Forums
Altimeter sensor
edited 2000-03-31 05:10 in General Discussion
Hi All
Does anybody know of a good altimeter sensor to measure height, this
has to be interfaced to my BS2 stamp, also when we calibrate these
sensors on he ground if we are passing over a hill for example will the
height be measured from the top of the hill or from the reference
point, did anybody use any sensorss to measure height and how did they
interface to the stamp, what code did they use.
thanks in advance
Paul..
    edited 2000-03-30 16:25
    Have a look at Shaun Wilson's page -- I'm partial since he uses a PAK-II for
    engineering unit conversion.
    http://geocities.com/SiliconValley/Orchard/6633/altimeter.html
    Al Williams
    AWC
    * Expand your Stamp's I/O with a PAK-III or PAK-IV I/O coprocessor:
    http://www.al-williams.com/awce/pak3.htm
    > From: Paul [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xnNQvxpo7H2HNFnhCvSV_ArQzDEGWJvR9hNeqGj1s224f9CtM5UE6MVkKAcrBRaXt8fCkbpR16623Q]paul.byrne@b...[/url
    > Sent: Thursday, March 30, 2000 9:18 AM
    > To: basicstamps@eGroups.com
    > Subject: [noparse][[/noparse]basicstamps] Altimeter sensor
    > Hi All
    > thanks in advance
    > Paul..
    > -- 20 megs of disk space in your group's Document Vault
    > -- http://www.egroups.com/docvault/basicstamps/?m=1
    edited 2000-03-30 16:59
    At 07:17 AM 3/30/00 -0800, Paul wrote:
    >Hi All
    >thanks in advance
    Here's a BS2 altimeter project using the motorola MPX series of pressure
    gauges. These are about $20.00 I think.
    http://www.geocities.com/SiliconValley/Orchard/6633/altimeter.html
    this fellow is getting a resolution of about 1 meter.
    best, Duncan
    edited 2000-03-31 00:47
    Paul,
    There should be enough on my page to get you going. If you have any problems
    free feel to email me and i will help you out.
    Ive been working on a pocket version of my altimeter. Its basically done,
    but i have yet to get pictures, code, schematics, and such up on my page. I
    designed and etched a PCB for it as well, i will have the pcb layout on
    there too.
    Since size was an issue i couldnt use the PAK II, i had use other methods to
    do the math. I used a method called linearization to repersent the non
    linear relationship of pressure vs altitude.
    Linearization is where you take a non linear equation and repersent it by a
    bunch of linear ones changing in slope at intervals along the curve.
    It has the following functions:
    altitude, pressure, max/min altitude, logs altitude to an 64k eeprom
    displays contents of eeprom, and has two calibration methods, manually
    where you enter the sea level pressure your self or auto calibrate where
    just press a button and it set the base pressure to the current pressure.
    I wanted to add a decent/ascend rate but i ran out of ram and eeprom.
    If anyone want the code, pcb layout, schematic just ask and i will email it
    to you derictly.
    Shaun,
    >for
    >Regards,
    >Al Williams
    >AWC
    > > Hi All
    > > thanks in advance
    > > Paul..
    >eGroups.com home: http://www.egroups.com/group/basicstamps
    >http://www.egroups.com - Simplifying group communications
    ______________________________________________________
    Just as an aside, if you want quantities, we can (and have) provide any of
    the PAKs in surface mount packaging. The problem is we have to have them
    made, and we don't stock them so this is really only practical if you need a
    fair number. Like anything else, the cost is setting it up, so to have 1 or
    2 made is pretty expensive.
    Just thought I'd mention that -- not practical for ones or twos, but if you
    are ever doing production that is possible.
    Al Williams
    AWC
    * Add a PS/2 keyboard to your Stamp, PIC, or other microcontroller project:
    http://www.al-williams.com/awce/pak6.htm
    > From: Shaun Wilson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=V4sY-G4rwqJTIAnU03JiFusrw2P2rR16DhPC_bp9mkXK56fKlZZPsY8oWs3IoGQ5HKvzwwPuux_bqWY_k64]shaunwilson@h...[/url
    > Sent: Thursday, March 30, 2000 5:48 PM
    > To: basicstamps@egroups.com
    > Subject: [noparse][[/noparse]basicstamps] Re: Altimeter sensor
    > Paul,
    > any problems
    > my page. I
    > there too.
    > methods to
    > repersent it by a
    > will email it
    > to you derictly.
    > Shaun,
    > >for
    > >Regards,
    > >Al Williams
    > >AWC
    > > > Hi All
    > example will the
    > > > thanks in advance
    > > > Paul..
    > -- Easily schedule meetings and events using the group calendar!
    > -- http://www.egroups.com/cal?listname=basicstamps&m=1
