off topic, obd II to serial — Parallax Forums
edited 2000-03-28 05:51 in General Discussion
Does anyone know of an inexpensive source
for an ODB II - to - serial chip/kit/method??
I'm trying to build a reader for the
chrysler jeep cheroke vehicle.
Rick
also, off topic, I never seem to get through
to the list by just emailing to 'basicstamps@egroups.com';
I'm always forced to use their web page. What am I doing
wrong when using 'direct' email??
thanks
    edited 2000-03-27 07:41
    At 12:33 PM 3/26/00 -0800, R. Denzer promulgated:
    From what I've seen to date, it would be very difficult, if not impossible to
    do with a Stamp. With a PIC it might be doable - so you might check the PIC
    lists.
    I have NO IDEA what state the PIC lists are in at present.
    >Thanks
    >Rick
    >thanks
    >-- Easily schedule meetings and events using the group calendar!
    >-- http://www.egroups.com/cal?listname=basicstamps&m=1
    edited 2000-03-27 15:04
    Check http://www.obd2.com/
    He has a preprogrammed PIC that will allow you to get OBDII data.
    I havent been able to get the stuff to work on certain cars through.
    To: <basicstamps@egroups.com>
    Sent: Sunday, March 26, 2000 11:41 PM
    Subject: [noparse][[/noparse]basicstamps] Re: off topic, obd II to serial
    to
    PIC
    > lists.
    > >Thanks
    > >Rick
    > >thanks
    > eGroups.com home: http://www.egroups.com/group/basicstamps
    > http://www.egroups.com - Simplifying group communications
    edited 2000-03-27 15:07
    Sorry its http://www.obd-2.com/
    Sent: Monday, March 27, 2000 7:04 AM
    > From: Bruce Bates <bvbates@u...>
    impossible
    > to
    > PIC
    > > lists.
    > > >Thanks
    > > >Rick
    > > >thanks
    > -- Check out your group's private Chat room
    > -- http://www.egroups.com/ChatPage?listName=basicstamps&m=1
    edited 2000-03-28 01:32
    No, the cables require special software to work. If you look on the page
    there he has a ISO chip for OEM applications.
    http://www.obd-2.com/chip.htm
    Sent: Monday, March 27, 2000 9:51 PM
    > a) Are you referring to the various $30 - $50 cables with serial
    > terminator? Is this enough for raw data gathering?
    > b) On a BasicStamp (or Windows terminal emulator) can you view the raw
    data
    > from the cable?
    > Thanks,
    > Larry Pfeffer
    impossible
    > >to
    > >PIC
    > >> lists.
    > >> >Thanks
    > >> >Rick
    > >> >thanks
    > eGroups.com Home: http://www.egroups.com/group/basicstamps/
    b) On a BasicStamp (or Windows terminal emulator) can you view the raw data
    from the cable?
    Larry Pfeffer
    >to
    >PIC
    >> lists.
    >> >Thanks
    >> >Rick
    >> >thanks
