Battery Status — Parallax Forums
Battery Status
edited 2000-03-19 13:12 in General Discussion
Stampers
I am looking for an easy way for the Stamps 2 to check the battery status of
a 12 volt battery. Any ideas?
Thank you
    edited 2000-03-15 13:52
    I just did an app. that had to monitor a 12 to 36v power supply with a
    MAX187 12bit serial ADC. This thing worked great, and there's code
    available for a BSII. Get the chip and the datasheet at:
    http://www.maxim-ic.com
    Get the code at:
    http://www.hth.com/filelibrary/BS2-IC/
    There's two versions of the code here, each slightly different. To measure
    12V, you'll have to use a voltage divider to the ADC. If you don't know
    what that is, there's a nifty online (java) calculator at:
    http://www.woodsbas.demon.co.uk/calcs/vdivide.htm
    Best, Duncan
    edited 2000-03-15 14:08
    The simplest way is usea a series resistor divider and check if battery is
    above or bellow a determined limit.
    (10 v for example.) A pin have a treshhold about 1.4 volt. Other available
    pins may be used to check other
    limits.
    ACJacques.
    Trkeenan@a... wrote:
    > Stampers
    > Thank you
    > -- Easily schedule meetings and events using the group calendar!
    > -- http://www.egroups.com/cal?listname=basicstamps&m=1
    edited 2000-03-15 16:00
    > battery status of a 12 volt battery. Any ideas?
    RCtime can do this.
    http://www.emesystems.com/BS2misc.htm#RCtime
    470 ohm 100 kohm
    P0 ----/\/\/\---o
    /\/\/\----Vx unknown voltage
    ===== 0.1 uF film
    Vss
    And the BS2 test program is:
    tx var word ' RCtime value
    vx var word ' voltage value to be determined
    Cn1 con 65000 ' first constant
    Cn2 con 14 ' second constant
    low 0
    loop:
    RCtime 0,0,tx
    low 0
    vx=Cn1 / tx - Cn2 / 2
    debug home,dec? tx,"vx=",dec vx/10,".",dec1 vx
    pause 1000
    next
    To calibrate, put a known voltage (say 12.6 volts) input at Vx an see what
    answer you get out. Adjust the proportionality constant Cn1 to make it
    come out right. Then put in a lower voltage (say 6.4 volts), and this time
    adjust Cn2. Repeat for desired accuracy. It is accurate over a narrow
    range of voltages typical of batteries in normal use.
    -- Tracy Allen
    Electronically Monitored Ecosystems
    edited 2000-03-16 01:46
    of
    I needed such a critter and found a MAX666 from Maxim. I needed a device to
    monitor a 12V gel cell and turn on a LED when it's voltage dropped to 10.5
    volts. The 666 can do this. The indicating voltage is user settable. I have
    the Maxim data sheet in .PDF format if you cannot find it on Maxim's web
    site:
    www.maxim-ic.com
    Contact me OFF-LIST if you need the data sheet. Don't clog up the list with
    requests.
    Hope this helps.
    Vic
    _________________________________________
    Victor Fraenckel vfraenc1@n...
    Home of the WindReader Electronic Theodolite
    Read the WIND
    edited 2000-03-16 02:15
    You can use an voltage comparator. I can explain how to do this if you
    e-mail me back.
    Derek
    >of
    edited 2000-03-18 14:52
    Thanks for all the ideas
    tim
    In a message dated 03/15/2000 9:11:14 AM Mountain Standard Time,
    emesys@c... writes:
    << > I am looking for an easy way for the Stamps 2 to check the
    RCtime can do this.
    Nice web page. Thanks for your help. The battery monitor idea worked real
    well.
    Tim
