SSR Cooling — Parallax Forums
SSR Cooling
CPUMANCPUMAN Posts: 55
edited 2004-09-27 14:10 in General Discussion
I just got some SSR's I won off eBay and I noticed the back·has a metal plate instead of plastic like the rest of the case.· Am I correct in assuming this plate is for attaching a heatsink?· The relays·are rated at 10A @ 220V.· Do I need a heatsink for them, if·they're running at a·load of about 50%·they're max?
Chris
  • Jonny555Jonny555 Posts: 46
    edited 2004-09-25 17:04
    Have you checked the spec sheet for the relay?
    The metal plate may infact be the heatsink, I've not seen a relay with a heat sink mounted externally. If the relay gets too hot during operation, it may not be the right relay for the job.
  • Sing AmericaSing America Posts: 17
    edited 2004-09-27 03:05
    Hi All,
    I have a siemens 9530, PD4437 display unit which I can not find the pin placement for. There are 10 a side and Siemans PDF showing the unit only shows the distance between the pins. The website also does not have a contact for e-mail questions. Has anyone here used this display unit and can help me with the pin configurations.
    Thanks Mark
  • dbpagedbpage Posts: 217
