Time recorder and uploader project - newbie
My project idea is this:
Each time a button is pressed the module records the time. At some point the module is connected to a PC (serial/usb) and all the recorded times are uploaded.
Firstly, is this too advanced for a newbie project.
Secondly, is basic stamp the best microcontroller for this kind of project.
Thanks a lot for your help.
r
r
And yes, if you add an external 'Real-time clock', any of the BS2 variants should be capable of handling this task.
(If you want to log a large number of records, you may want to consider the BS2sx, BS2P or BS2Pe as they have more space)
Al Williams
AWC
Add Floating Point Math to Your Stamp
http://www.awce.com/pak12.htm
So to reiterate Al, after reading your project of the month. I could write the time/date to the DS1307 each time a button is pressed. Then upload those time/dates to the PC. Would this uploading be possible to do in runtime using your ASP III prototyping board?
Hope I haven't said anything stupid there.
r
Jon Williams
Dallas Office
There are some subtle areas to this, but it isn't anything you can't figure out.
The ASP-III is great for this because it can hold the clock chip, the crystal, the BS2P, and has a PC-compatible serial port onboard. So you would have a single piece of hardware with very few modifications required. You would need to use a few of the spare holes for a pull up resistor and a connection to your switch, but there is plenty of room for that.
Al Williams
AWC
KITS!
http://www.awce.com/kits.htm
