ptra[index] vs ptra++[index] — Parallax Forums
using PNUT V35L i compile this little listing:
DAT
    rdbyte $1, ptra     '1      $FAC40300
    rdbyte $1, ptra[0]  '2      $FAC40300
    rdbyte $1, ++ptra   '3      $FAC40341
    rdbyte $1, ++ptra[1]    '4      $FAC40341
Line 1 and 2 produces the same opcode. So index=0 means you can omit it.
line 3 and 4 produce the same opcode. So index=1 means you can omit it.
somehow i do not understand why the index is based 0 on line 1 and 2 but seems to be based 1 on line 3 and 4?
can someone enlighten me?
  • Wuerfel_21Wuerfel_21 Posts: 4,509
    edited 2021-04-21 18:14
    With PTRA++/++PTRA, the index is what gets added to PTRA, so it defaults to 1.
  • SuracSurac Posts: 176
    edited 2021-04-21 18:42
    ah so the syntax is misleading. in line 3 and 4 is no index but a operand for an addition.
    rdbyte $1, ptra++[3] means "use ptra then add 3"
    and
    rdbyte $1, ++ptra[3] means "use ptra+3 then add 3"
    but
    rdbyte $1,ptra[3] menas "add 3 to ptra and use it, but do not change ptra"
    right?
  • The syntax may seem misleading, but it makes sense.
    rdbyte $1, ptra means "use ptra"
    rdbyte $1, ptra++ means "use ptra and then add 1"
    rdbyte $1, ++ptra means "add 1 and then use ptra"
    rdbyte $1, ptra[3] means "use ptra + 3"
    rdbyte $1,++ptra[3] means "add 3 and then use ptra"
    rdbyte $1, ptra++[3] means "use ptra and then add 3"
    It seems logical to me.
  • hmm
    doesn't it mean
    add 1 to ptra either before or after the operation and use a offset of 3 to the value used?
    edited 2021-04-22 09:11
    @msrobots said:
    hmm
    doesn't it mean
    That's what it means in C. But unfortunately, Chip simply ignored C and @"Dave Hein" is right.
    I also was lured into the "C" interpretation of the syntax and collided with a "syntax iceberg". Now my brain is sinking and all passengers rush to the lifeboats :smile:
    edited 2021-04-22 09:23
    Also to mention PNUT accepts some real wired syntax errors and just emits something
    • rdbyte $1F , ptra++[##-$10] (impossible instruction) gets to RDBYTE $1F, PTRA-- [##$10]
    • rdbyte $1F , ptra++[##$8_0001] (field size of index ignored and misused sign bit) get RDBYTE $1F, PTRA-- [##$7FFFF]
    • rdbyte $1F , ptra--[##$-8_0001] (sign in index should not be possible) gets RDBYTE $1F, PTRA++ [##$13881]
    • rdbyte $1F , ptra--[#$8] (gives a syntax error, because non ## constants must be written without # inside index)
    I know most of the above instructions are brain dead all the way, but i use PNUT to compile such things to test if my disassembler is able to decode the instruction
