Looking for Spin example to look up a value in a list — Parallax Forums
I've been messing around with Beau Schwabe's 4x4 keypad demo. It produces a word and depending on which key is pressed sets a bit in the word. The keypad I have has these keys in the order in which I see the bits set (*, 0, #, D, 7, 8, 9, C, 4, 5, 6, B, 1, 2, 3, A). For instance 0100000000000000 would be the "0" key pressed.
How do I iterate through the list to get the corresponding character that aligns with the bit set in the word?
  • Don MDon M Posts: 1,647
    edited 2021-04-17 16:56
    I got this to work:
    VAR
      word  keypad
    PUB start | idx
      ' Start PST
      text.start(115200)
      repeat
        keypad := KP.ReadKeyPad
        repeat idx from 0 to 15
          if (keypad >> idx) == 1
            text.position(5, 2)
            text.str(@keys[idx])
    DAT
      keys  word  "A", "3", "2", "1", "B", "6", "5", "4", "C", "9", "8", "7", "D", "#", "0", "*"
    Is there any better or simpler way?
    BTW how do you post code in the forum. I tried [/code] and [\code]...
  • Triple backticks, like this:.
    Code goes here
    Thanks. I changed it.
    edited 2021-04-17 21:41
    Here is the code!
    https://github.com/parallaxinc/propeller/blob/master/libraries/community/p1/All/4x4 Keypad Reader DEMO/4x4 keypad Reader DEMO.spin
    You can also use a CASE statement.
    Not necessarily better, just easier to read.
    And then list all possible states for the keypad
      repeat
        keypad := KP.ReadKeyPad     '<-- One line command to read the 4x4 keypad
        text.str(string($A,5,$B,2))
        text.bin(keypad>>0, 4)      'Display 1st ROW
        text.str(string($A,5,$B,3))
        text.bin(keypad>>4, 4)      'Display 2nd ROW
        text.str(string($A,5,$B,4))
        text.bin(keypad>>8, 4)      'Display 3rd ROW
        text.str(string($A,5,$B,5))
        text.bin(keypad>>12, 4)     'Display 4th ROW
        text.str(string($A,5,$B,9))
        text.bin(keypad, 16)        'Display RAW keypad value
        Case Keypad
           %0100000000000000:     'Zero key pressed.
             Do something
           %0000000000000000:     'No key pressed
             Do something
    You can find the correct binary number when you see what the RAW keypad value is on your terminal output.
    You can then place that entire binary number into the CASE statement like I did for two of the binary positions.
  • JonnyMacJonnyMac Posts: 8,927
    edited 2021-04-17 21:35
    No need to iterate. The >| (encode) operator will tell you which bit is set (+1). This routine will turn your bit into an ASCII character.
    dat
      KeyChar       byte    "*0#D789C456B123A"
    pub translate_key(keybits)
      if (keybits)
        return KeyChar[>|keybits - 1]
    This will return 0 if no key was pressed, or the ASCII char if one was.
  • AribaAriba Posts: 2,682
    Or:
        keychar := lookup( >|keypad : "*0#D789C456B123A")
    Thanks for the help. Much appreciated.
