Shop Learn
Original ActivityBot possible project — Parallax Forums
I am using the original Activity Board on the Bot chassis, that I have. Below is a little test program, and it comes up with an error, when compiled. Are those libs corrupted, or is there something else that should be added to the program.
Thanks Ray
ab_test1.c
include "simpletools.h"
include "abcalibrate.h"
include "abdrive.h"
int main()
// Add startup code here.
while(1)
// Add main loop code here.
Project Directory: F:/programs/ab_test1/ab_test1/
SimpleIDE Version 1.1.2
C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/
C:/Users/ray/Documents/SimpleIDE/ Updated on: 2020-12-19
propeller-elf-gcc.exe -v GCC 4.6.1 (propellergcc_v1_0_0_2408)
propeller-elf-gcc.exe -I . -L . -I C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/Robotics/ActivityBot/libabcalibrate -L C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/Robotics/ActivityBot/libabcalibrate/cmm/ -I C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/Robotics/ActivityBot/libabdrive -L C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/Robotics/ActivityBot/libabdrive/cmm/ -I C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools -L C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools/cmm/ -I C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext -L C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext/cmm/ -I C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c -L C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c/cmm/ -I C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/Motor/libservo -L C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/Motor/libservo/cmm/ -I C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libfdserial -L C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libfdserial/cmm/ -o ab_test1.elf -Os -mcmm -m32bit-doubles -fno-exceptions -std=c99 ab_test1.c -lm -labcalibrate -labdrive -lrate -lsimpletools -lsimpletext -lsimplei2c -lservo -lfdserial -lm -labcalibrate -labdrive -lrate -lsimpletools -lsimpletext -lsimplei2c -lservo -lm -labcalibrate -labdrive -lrate -lsimpletools -lsimpletext -lsimplei2c -lm -labcalibrate -labdrive -lrate -lsimpletools -lsimpletext -lm -labcalibrate -labdrive -lrate -lsimpletools -lm -labcalibrate -labdrive -lrate -lm -labcalibrate -labdrive -lm -labcalibrate -lm
c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/bin/ld.exe: cannot find -lrate
collect2: ld returned 1 exit status
Done. Build Failed!
  • Ray, do this first https://learn.parallax.com/tutorials/language/propeller-c/propeller-c-set-simpleide/update-your-learn-folder and try again.
    Also, which tutorial are you working from in this series? Seems you might be in here https://learn.parallax.com/tutorials/robot/activitybot/activitybot/navigation-basics.
  • Ken GraceyKen Gracey Posts: 7,246
    edited 2021-04-07 20:23
    Looking at this a bit more, usually the calibrate library is used with simpletools (but not with abdrive.h, concurrently):
    // ------ Libraries and Definitions ------
    // ------ Main Program ------
    int main() {
    cal_servoPins(12, 13);
    cal_encoderPins(14, 15);
    high(26);
    high(27);
    cal_activityBot();
    low(26);
    low(27);
    I don't know why the above text is so BOLD, either. Something about the include word.
    In your code, I see it combined with other libraries abdrive too. You might be running out of memory, too. I think the first thing to do is make sure you've got the Simple IDE workspace updated. I may not be able to return to this thread until Thursday.
  • dgatelydgately Posts: 1,441
    Firstly, your 'include" statements need to be '#include' :
    #include "simpletools.h"
    #include "abcalibrate.h"
    #include "abdrive.h"
    Fix that and it will either compile or give you a more informative error message. It appears that the "cannot find -lrate' error is because the include (and not #include) lines are being fragmented as the preprocessor tries to interpret them... The 'rate' in '-lrate' is part of 'abcalibrate'.
    dgately
    dgately
    @dgately notice my code has the same problem. This forum software is stripping out the # character in front of the include.
    Ken
  • Dennis, how do you format for code inclusion with this forum tool? I should know. . . .
    Steps:
    1. type 3 backticks
    2. type return
    3. enter my code lines (type them in or copy paste them)
    4. type return
    5. type 3 backticks
    6. type return
    // C type comment
    #include "stdio.h"
    It will look like this until you type return after the last 3 backticks:
    // C type comment
    #include "stdio.h"
    I did a trick by preceding the backticks & hash with a backslash in the above example just to show how it looks...
  • RsadeikaRsadeika Posts: 3,537
    In my code it is "#include "simpletools.h", for some reason when I pasted the code to the post, it stripped away the "#".
    I just tried the four different Learn folders, and each one comes up with the same errors. I am using the latest SimpleIDE download, so, I am not sure what is going on.
    The SimpleIDE version that is installed, I use to program all my other programs, with no problems showing up. With that said, I think maybe the Libs are corrupted.
    Ray
    Back to Ray's problem...
    Yes, updating SimpleIDE's Learn folder should help... I'm able to compile, with just some warnings about __simple_printf...
    Project Directory: /myUser/Desktop/
    SimpleIDE Version 1.1.0
    /myUser/Documents/SimpleIDE/Learn/Simple Libraries/
    /myUser/Documents/SimpleIDE/ Updated on: 2020-03-10
    propeller-elf-gcc -v GCC 4.6.1 (propellergcc_v1_0_0-36-g4c46ecb)
    propeller-elf-gcc -I . -L . -I /myUser/Documents/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools -L /myUser/Documents/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools/lmm/ -I /myUser/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext -L /myUser/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext/lmm/ -I /myUser/Documents/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c -L /myUser/Documents/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c/lmm/ -I /myUser/Documents/SimpleIDE/Learn/Simple Libraries/Robotics/ActivityBot/libabcalibrate -L /myUser/Documents/SimpleIDE/Learn/Simple Libraries/Robotics/ActivityBot/libabcalibrate/lmm/ -I /myUser/Documents/SimpleIDE/Learn/Simple Libraries/Motor/libservo -L /myUser/Documents/SimpleIDE/Learn/Simple Libraries/Motor/libservo/lmm/ -I /myUser/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libfdserial -L /myUser/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libfdserial/lmm/ -I /myUser/Documents/SimpleIDE/Learn/Simple Libraries/Robotics/ActivityBot/libabdrive -L /myUser/Documents/SimpleIDE/Learn/Simple Libraries/Robotics/ActivityBot/libabdrive/lmm/ -o raysCode.elf -Os -mlmm -m32bit-doubles -fno-exceptions -Dprintf=__simple_printf raysCode.c -lsimpletools -lsimpletext -lsimplei2c -labcalibrate -lservo -lfdserial -labdrive -lsimpletools -lsimpletext -lsimplei2c -labcalibrate -lservo -lfdserial -lsimpletools -lsimpletext -lsimplei2c -labcalibrate -lservo -lsimpletools -lsimpletext -lsimplei2c -labcalibrate -lsimpletools -lsimpletext -lsimplei2c -lsimpletools -lsimpletext -lsimpletools
    In file included from /myUser/Documents/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools/simpletools.h:118:0,
                     from raysCode.c:6:
    /myUser/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext/simpletext.h:309:1: warning: '__simple_printf' is an unrecognized format function type [-Wformat]
    propeller-load -s raysCode.elf
    propeller-elf-objdump -h raysCode.elf
    Done. Build Succeeded!
    I downloaded and installed the latest version of SimpleIDE:
    C:/Users/ray/Documents/SimpleIDE/ Updated on: 2021-04-07
    I noticed that you are using:
    Is their some kind of difference between 1.1.0 and 1.1.2 versions. Yes, with the latest download, I am still getting those errors.
    Ray
    edited 2021-04-07 21:58
    Ray
    Interesting... I actually have several versions of SimpleIDE ;)
    I just downloaded the latest SimpleIDE for macOS and it is: version 1.1.0...
    I actually use a 1.0.2rc version because it allows me to use the old non-project set up as well as spin-based projects rather than just C...
    Today I tried out the ..360 libs, I am getting the same errors. I am using a Windows 10 setup, so everything should be working as expected. It looks like the Libs are out of sync with SimpleIDE.
    I know that Parallax is pushing Blockly, but I was hoping that they would keep SimpleIDE around for a lot longer.
    Ray
    ab_test1.c
    include "abcalibrate360.h"
    include "abdrive360.h"
    int main()
    //calServoPins(12,13);
    high(26);
    high(27);
    //cal_activityBot();
    low(26);
    low(27);
    //while(1)
    Project Directory: C:/Users/ray/Documents/SimpleIDE/My Projects/ab_test1/
    propeller-elf-gcc.exe -I . -L . -I C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/Robotics/ActivityBot/libabcalibrate -L C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/Robotics/ActivityBot/libabcalibrate/cmm/ -I C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/Robotics/ActivityBot/libabdrive -L C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/Robotics/ActivityBot/libabdrive/cmm/ -I ./../../Learn/Simple Libraries/Robotics/ActivityBot/libabcalibrate -L ./../../Learn/Simple Libraries/Robotics/ActivityBot/libabcalibrate/cmm/ -I ./../../Learn/Simple Libraries/Robotics/ActivityBot/libabdrive -L ./../../Learn/Simple Libraries/Robotics/ActivityBot/libabdrive/cmm/ -I ./../../Learn/Simple Libraries/Robotics/ActivityBot360/libabcalibrate360 -L ./../../Learn/Simple Libraries/Robotics/ActivityBot360/libabcalibrate360/cmm/ -I ./../../Learn/Simple Libraries/Robotics/ActivityBot360/libabdrive360 -L ./../../Learn/Simple Libraries/Robotics/ActivityBot360/libabdrive360/cmm/ -I C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools -L C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools/cmm/ -I C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext -L C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext/cmm/ -I C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c -L C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c/cmm/ -I C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/Motor/libservo360 -L C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/Motor/libservo360/cmm/ -I C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libfdserial -L C:/Users/ray/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libfdserial/cmm/ -o cmm/ab_test1.elf -Os -mcmm -m32bit-doubles -fno-exceptions -std=c99 ab_test1.c -lm -labcalibrate -labdrive -labcalibrate360 -labdrive360 -lrate -lrate360 -lsimpletools -lsimpletext -lsimplei2c -lservo360 -lfdserial -lm -labcalibrate -labdrive -labcalibrate360 -labdrive360 -lrate -lrate360 -lsimpletools -lsimpletext -lsimplei2c -lservo360 -lm -labcalibrate -labdrive -labcalibrate360 -labdrive360 -lrate -lrate360 -lsimpletools -lsimpletext -lsimplei2c -lm -labcalibrate -labdrive -labcalibrate360 -labdrive360 -lrate -lrate360 -lsimpletools -lsimpletext -lm -labcalibrate -labdrive -labcalibrate360 -labdrive360 -lrate -lrate360 -lsimpletools -lm -labcalibrate -labdrive -labcalibrate360 -labdrive360 -lrate -lrate360 -lm -labcalibrate -labdrive -labcalibrate360 -labdrive360 -lrate -lm -labcalibrate -labdrive -labcalibrate360 -labdrive360 -lm -labcalibrate -labdrive -labcalibrate360 -lm -labcalibrate -labdrive -lm -labcalibrate -lm
    c:/program files (x86)/simpleide/propeller-gcc/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/bin/ld.exe: cannot find -lrate360
    Done. Build Failed!
