Anyone have some spin code to find largest value in an array? — Parallax Forums
A byte array of 16 bytes.
Thanks.
  • JonnyMacJonnyMac Posts: 9,608
    edited 2021-03-12 23:53
    You could make a general-purpose method that will work with any array type of any size:
    pub find_max(p_array, bsize, count) : maxval | check
      maxval := negx
      repeat count
        case bsize
          1 :
            check := byte[p_array]
            p_array += 1
          2 :
            check := word[p_array]
            p_array += 2
          4 :
            check := long[p_array]
            p_array += 4
        if (check > maxval)
          maxval := check
    As Phil points out, all the math done in this method uses longs, so there is not need to check size when setting the initial value of maxval.
    edited 2021-03-12 22:59
    Jon,
    I think you can do this regardless of bsize:
    maxval := negx
    since the math is all done in longs anyway. Saves an if.
  • Don MDon M Posts: 1,654
    Well I thought I did. Evidently I don't know how to use it.
    VAR
    byte Buff1[16], MaxResult
    In this array I have these numbers stored: $01, $02, $05, $14, $FE, $00, $00, $00, $00, $00, $38, $00, $00, $00, $00, $00
    I tried this method from @Kuroneco
    pub
    MaxResult := maxval2(@Buff1, 16)
    term.hex(MaxResult, 2)
    pub maxval2(addr, n)
    addr := (addr - @addr) >> 2
    result := addr[addr++]
    repeat n - 1
    result #>= addr[addr++]
    I'm not sure what it's supposed to give me. The actual largest number ($FE) or the index of the largest number (4). It gives me 0.
    Help!
    edited 2021-03-12 23:51
    Good point, Phil.
    edited 2021-03-13 00:00
    Saving another if:
    maxval #>= check
    Of course, that might be totally opaque to a lot of people. Reason enough not to use it, I s'pose.
    edited 2021-03-13 00:15
    Since you only care about bytes, here's a simple version. I tested on a byte array with 25 values and it found the correct maximum.
    pub get_max(p_array, count) : maxval | check
      repeat count
        check := byte[p_array++]
        if (check > maxval)
          maxval := check
    What you're doing with the array pointer seems convoluted. When using pointer, you need to tell Spin what size value you are taking from that pointer -- in this case, a byte.
    You could shorten the code a bit...
      repeat count
        maxval #>= byte[p_array++]
    ... but the infinitesimally small performance gain is not worth the non-obvious code (my opinion, of course). I always strive to write obvious code.
