P2 Propeller Tool & pasm jmp — Parallax Forums
Can't the Propeller Tool in PASM make jumps over cells deffined with long?
DAT     org                       '        '
        asmclk                    '        '
.loop                             '        '
        call    #.dac1            '        '
        call    #.adc2            '        '
        jmp     #.loop            '        '
' DAC        '
.dac1                             '        '
        ret                       '        '
' Variabeln        '
outw     long  0                   '        '
' ADC        '
.adc2                             '        '
        ret                       '        '
' Variabeln        '
inw    long  $8000               '        '
  • msrobotsmsrobots Posts: 3,704
    edited 2021-03-12 11:50
    you use local labels with "."
    but have not local labels in between.
    So remove the "." from labels and calls.
    Gruss,
  • evanhevanh Posts: 15,192
    Or put dots at start of all the labels.
  • I have now killed the points.
    I guess I got carried away with the examples.
