Shop Learn
Format Propeller to Python? — Parallax Forums
Does anyone know if you can format a Propeller chip to be programmed in Python?
I would like to swap my current Props to Python.
  • Hello Alman,
    The P2 can be programmed in Python https://www.parallax.com/propeller-2/get-started/micropython/
  • Unfortunately the Propeller 1 lacks the amount of RAM needed to run MicroPython. As Ken stated, however, the P2 does run MicroPython.
  • AImanAIman Posts: 528
    I was hoping to run Python without needing to learn a dialect.
    A thought just occurred to me.
    Can I run my P1 on Python using a I2C 512k EEprom as RAM?
  • yetiyeti Posts: 767
    MicroPython is a Python dialect
    It would be far too slow and die too soon.
    Chips or boards running MicroPython are far cheaper than their Propeller equivalents. Look at the ESP8266/ESP32 family or laaater at the new Raspi-Pico. Give the PiPico still some time, it seems not to be free from hiccups yet.
  • On the subject of MicroPython boards, Parallax sells the Micro:bit unit as well as a BOE shield to mount it on a BOE-Bot. The Micro:bit is designed to use MicroPython and should be relatively easy to integrate into most propeller projects. https://www.parallax.com/product/cyberbot-conversion-kit/
    edited 2021-02-23 20:21
    Micro:bit is very tight.
    You get beefier critters (RAM and speed wise) for less bucks.
    But ok, in some contexts the eco system around the Micro:bit might be the biggest decision influence.
    MicroPython v1.13 on 2020-09-02; ESP module with ESP8266
    Type "help()" for more information.
          import gc
    Yip yip, 1.14 is the current stable release, but all my µPy-1.14 on ESP8266 critters sleep right now.
    So ~36k free on el cheapo ESP8266 (ESP12 variant) and on newer ESP32 modules you can have up to 4MBytes free for µPy.
    ... the code block above is broken, I hope someone able to fix it will have a look...
    The borken code block as image
    The simplest ESP32 chips have ~100k free, the biggest (I know of) 4M free.
