SOLVED: Converting DS1302 driver from P1 to P2 question — Parallax Forums
dgatelydgately Posts: 1,621
edited 2021-01-02 06:07 in Propeller 2
Excuse my simplistic code conversion...
I'm sure there's a much simpler solution in Spin2, but I'm trying to start with a literal translation from P1 Spin. I'm trying to send out the command byte to the DS1302, one bit at a time, in the following excerpt:
pub main()
  setup()
  wait_for_terminal(true)
  write_a_byte(%10000101)			'' $85 DS1302 read hours command
PRI write_a_byte( cmd ) | i
'' P1 dira & outa version
  dira[io]~~              ' set to output
  repeat i from 0 to 7
    outa[io] := cmd   ' send the LSB bit to the IO pin ???
    outa[clk]~~
    cmd >>= 1
    outa[clk]~
'' P2 Spin2 methods
    if (cmd & %00000001 == 1)       ' REPLACE: outa[io] := cmd for P2 ???
      pinhigh(io)                               ' the masked bit is 1
    else
      pinlow(io)                                ' the masked bit was 0
    pinhigh(clk)
    cmd >>= 1
    pinlow(clk)
The Spin2 version does not yet work (timing issue or just bad coding?)
dgately
  • JonnyMacJonnyMac Posts: 8,929
    edited 2021-01-01 22:28
    You can simplify a little bit. This is how I would translate that P1 code:
    pri wr_byte(cmd)
      repeat 8
        pinw(io, cmd)
        pinh(clk)
        cmd >>= 1
        pinl(clk)
    Since io is a single pin, the pinw() function will only write bit0 of cmd.
  • Thanks Jon!
    Changed my code, still not getting good results, but at least I think I understand how that piece of code works. Now, on to the rest of the code.
  • dgatelydgately Posts: 1,621
    edited 2021-01-02 03:19
    I'm down to one last function that should be a simple P1 to P2 conversion... I've actually been using the P1 version of the code, which flexprop happily translates for P2, but I would rather use code that will compile on PropTool, eventually. I'm unsure if the P1 "datar |= |< i" code works as P2 code. The global var, datar stays empty with the P2 code. All of the functions outside of this private function are working. When I comment the P2 variant and uncomment the P1 code, it works!
    Here's a code snippet with commented-out working P1 code (compiles with flexprop):
    VAR
      byte datar                 ' a GLOBAL var
    PRI readByte|i
    '' REMOVE P1 dira & outa
      datar~
        if ina[io] == 1
          datar |= |< i     ' set bit
        outa[clk]~~
        outa[clk]~
    '' P2 REWRITE
      datar := 0                    ' set datar to zero
        if (pinr(io) == 1)          ' is the pin high?
          datar |= |< i             '  yes, set the corresponding bit to 1
        pinh(clk)                   ' strobe the clock
        pinl(clk)
  • ozpropdevozpropdev Posts: 2,791
    edited 2021-01-02 03:45
    Change this line
    datar |= decod i             '  yes, set the corresponding bit to 1
    edited 2021-01-02 05:43
    ozpropdev wrote: »
    Change this line
    OK... that's the correct P2 replacement, but it still just returns with datar as 0. Is there any other difference from the P1 code?
    One more try and it works:
    PRI readByte|i
      datar~
        if ina[io] == 1
        outa[clk]~~
        outa[clk]~
        pinl(clk)
    edited 2021-01-02 06:01
    Here's another option.
    pri read_byte() : result | i
      pinf(io)                                              ' set to input
        result.[i] := pinr(io)
        pinh(clk)
        pinl(clk)
  • Keeps getting better! I just need to test all the functions and there will be a DS1302 driver for Spin2!
    Thx
