Will Parallax sell the 2 x 6 Harwin m20-7810645r connectors — Parallax Forums
Will Parallax sell the 2 x 6 Harwin m20-7810645r connectors for about
the price Mouser or Digikey would?
I was looking at the 6x2 smt connectors used on the P2 evaluation
boards to make a quick proto boards by soldering the Harwin 6x2
smt to a perf board.
The PCB layout specs in the data sheet makes it look like it is
possible. But since I don't have a Harwin m20-7810645r
connector in my hands to measure, I am just guessing.
According to the data sheet there are 2 plastic locating pins
that might be able to be cut or sanded off. Hopefully cutting
or sanding off the pins is easier than Sir Shakealot drilling a
centered hole in the perfboard?
Bill M.
1421 x 795 - 180K
    edited 2020-12-12 23:16
    Why not just use female thru hole sockets? Either a pair of 1x6 or single 2x6?
    You can cut down longer 1x?? while wasting a pin.
  • @"Capt. Quirk" you're not the first one to ask us this question. In the same way we have the socket for the P2 Edge (in three varieties) we can make these available too. I think we can offer them for the DigiKey/Mouser cost since we're buying in much larger quantities than 5-10 at a time.
    Will you place the first order if we add these to our site?
  • Capt. QuirkCapt. Quirk Posts: 872
    edited 2020-12-13 02:14
    Ken Gracey wrote: »
    Yup!
    I have a box of small double sided perf boards, that would be perfect
    for small test circuits and my ebay module collection.
    Cluso99 wrote: »
    I am hoping that it will be a cleaner solution to my solder globs
    I have created in the past.
    Bill M.
  • I'd buy some for sure!
