Math
in Propeller 1
I want to type in a number zero to 6000 and multiply it by .682 and make the result
an integer zero to 4095 to send to a 12 bit D/A. I can't get the math to work???
thank you for your support...
{{ test program
Con
_Clkmode = Xtal1 + pll16x
_Xinfreq = 5_000_000
multi = 0.682
Var
LONG outval 'end count
long inval 'start count
LONG oneval
Obj
pst: "Parallax Serial Terminal"
Pub main
pst.start(115_200) 'check the baud rate
pst.str(string("hello",$0D))
repeat
pst.rxflush
pst.str(string("Gimmie a number -- ",$0D))
inval:=pst.Decin
pst.str(string("got it... your answer is...",$0D))
outval := inval * multi
pst.Dec (outval)
It would help if you took one step back from how you calculated .682, which can be expressed as a numerator / denominator pair.
Multiply first, then divide.
outval := inval * 4095 / 6000
Thanks Whicker...
Bill.
Or multiply by 1000 you "multi = 0.682" => 682 so you avoid the fractions
And result "outval := (inval * multi) /1000
This assumes "value" is scaled by the value of "denominator".
PUB DecPoint(value, denominator) if value < 0 Pst.Char("-") -value if value => denominator result := value / denominator Pst.Dec(result) value //= denominator else Pst.Char("0") Pst.Char(".") repeat while denominator > 1 denominator /= 10 if value => denominator result := value / denominator Pst.Dec(result) value //= denominator else Pst.Char("0")
