How are drones getting the very long ranges RF?
T Chap
I was curious about some drones and how they are sending live video for 3000 ft. Does anyone know what method of RF they are using to control something at that range and get data back? I wish there was a way to control a prop via RF like that.
The Mavic Mini is rated at just under two and a half miles. The Mavic Pro, over six miles.
https://www.digikey.in/product-detail/en/laird-connectivity-inc/AC4490LR-1000M/AC4490LR-1000M-ND/1844881
SUCK THAT BATTERY.
650mA Transmit/Receive!
Hope you can swim!
Have you looked at any of the many inexpensive LoRa devices?
Andreas Spiess has a bunch of videos on this topic. Here's one of his videos.
Of course the range will be very different if there are obstacles between the radios.
I used a set of 900MHz XBee modules and I walked down the street with a laptop connected to one of the modules. The other module stayed inside and just echoed whatever it received. The radios worked fine a block apart but as soon as I put a car or house between the two radios the connection greatly degraded.
I think one reason drones get such good range is they're above obstacles which would block the signal.
BTW, XBees generally work well but they're much more expensive than many other alternatives which also work well.
