Shop Learn
Can Scott Edwards Mini SSC be programmed with Parallax? — Parallax Forums
Hey I'm new to this platform, any help is appreciated.
I have a Scott Edwards Mini SSC II for servo motor control.
Can I program this module using the Parallax BASIC Stamp IDE?
Thanks in advance!
  • PublisonPublison Posts: 11,858
    edited 2020-05-07 09:59
    Your duplicate question was deleted. Duplicates are not allowed.
    No Cross-Posting:
    Cross-posting is: 1) submitting a post to one forum or thread, and then submitting a second linking to the original post (without changing content or intent), or 2) creating an identical post in more than one forum or thread. When the same content is found in more than one post, even under different subject lines, the forum moderator will remove one (or more) of the redundant posts and the posting account may be subject to moderation.
  • If it’s based on a Basic Stamp, then you should be able to.
  • Base on a quick look the Mini SSC manual, it looks like the SSC receives serial commands.
    These serial commands can come from a BasicStamp or other device with a UART capable of 2400bps.
    To use control the SSC using the Parallax BASIC Stamp IDE you'd also need a Basic Stamp in order to use the SSC. You'd use the Parallax BASIC Stamp IDE to program the Basic Stamp which in turn would control the SSC. The Parallax BASIC Stamp IDE can't directly control or program the Mini SSC.
