fastspin CASE
ManAtWork
in Propeller 2
Is CASE different in fastspin compared to P1 spin? I just tried to compile the FloatString library. It's plain spin so I thought it should also work on the P2. However,
If I replace it by
case exponent 'in range left of decimal 11..0: AddDigits(exponent + 1) 'in range right of decimal -1..digits - 13: zeros := -exponent AddDigits(1) 'out of range, do scientific notation other: DoScientificalways falls through to the "other" case no matter what the value of "exponent" is.
If I replace it by
if exponent => 0 AND exponent < 12 AddDigits(exponent + 1) elseif exponent < digits-13 DoScientific else zeros := -exponent AddDigits(1)it works as expected. Maybe the compiler has a problem with the left bound of "11..0" and "-1..digits-13" being higher than the right bound. I think it should throw an error if it can't cope with it.
