Smartpin adc value question — Parallax Forums
I just got the new replacement eval board, thank you very much again Chip and Ken, and I was testing the analog smartpin inputs. This time with the 3.3 and gnd pins on the eval board!! The first two pins were about 700 at 0 volts and 3600 at 3.3 volts, both about the same I think within 1 or 2. I tried another and it was about 100 higher with the same voltage. A third and fourth were off a little more each. Is this normal and each pin will have to be adjusted in the program to make them all equal? For now I just added or subtracted to equalize them and set 0 volts equal to 0 digital reading.
Is this the correct way or is there a better way to do it?
  • evanhevanh Posts: 15,235
    There is internal selections of voltage sources for the ADC input. For calibrating you want both GIO and VIO sources. These will tell you the numerical work range of 0 volts to 3.3 volts.
    Select config details are in ADC section here - https://forums.parallax.com/discussion/comment/1452036/#Comment_1452036
    edited 2020-01-19 01:29
    There has been discussions on best ways to continuously run live calibration for optimal DC drift elimination. Latest one was a follow on from the discussion over cutting a track on the silicon (the Rev C change) to reduce crosstalk on pin-pairs.
    It was suggested that instrumentation use would benefit from tying the pin-pairs together and alternating the sampling between signal and calibration. While one pin is reading the signal the other pin is being recalibrated.
  • Ok, so you do have to calibrate the pins for any variances. That's fine and I don't need any exact reading for what I'm doing with the gauges in the vehicle for fuel, oil, temp and O2 sensors.
    Just wanted to make sure it was normal.
  • I've been reading the posts on calibrating the adc and although most of it is over my head I see comments on GIO and VIO calibration being internal. Is there a way to read the GIO and VIO on a pin with a voltage connected to that pin. I have yet to find how you would do that in code.
    Am I just reading this wrong or can you somehow switch the mode to read GIO, VIO or actual pin voltage in the code?
    Tubular wrote: »
    It'll be interesting to see how they vary from pin to pin and chip to chip. Since those VIO and GIO calibration connections are purely internal, perhaps this is a way of obtaining a 'unique signature' of the silicon being tested. That would make for a kind of organic serial number.
  • OK I think I answered my question. I finally found a post about it. I see the first two adc modes are what I want, is that correct? So you switch the mode to GIO or VIO and read the pin.
    Some of this may sink in to this old head sometime.
  • cgraceycgracey Posts: 14,133
    The thing about switching ADC sources is that the first good SINC2 conversion is the 3rd one after the source change.
    edited 2020-01-19 05:42
    CRST1 wrote: »
    Yes, the WRPIN mode number contains the input selection in the %P bits.
    As Chip indicates, SINC2 mode provides highest resolution and it takes at least three "decimation" samples to settle.
    EDIT: Err, SINC3 mode is highest resolution. Just use the same conversion mode for the calibration as you're using for signal sampling.
  • I'm just about to test the smartpin ADCs. I tried a sampling period of 8192 clocks and SINC2 filtering. According to the docs it should give around 14 ENOB. I have some noise at the last bits but it's still much better than what I saw at other processors.
    I tookj the example from the google document and modified it for 14 instead of 8 bits resolution. It works but I had to place a zerox instruction after the shift.
    		shr	adc,#12	' log2(8192)-1 = 13-1
    		zerox	adc,#13	' 14 ENOB
    Without the zerox I sometimes get garbage in the bits above 13. I'm using the same waitse1 as in the example and my loop is quite short so I don't think I get overflows due to missed events.
    The untruncated resolution is log2(8192) * 2 = 26 bits. 26 - 12 = 14 bits, so if you're getting more then there has to be a bug. Can't say I've tested the hardware itself that precisely.
