midi input — Parallax Forums
midi input
anyone have a complete working and tested midi input project that i can use to test my board my design
  • Wuerfel_21Wuerfel_21 Posts: 5,385
    edited 2019-12-17 12:51
    There very likely is, but I don't really know where.
    HOWEVER,
    MIDI is just a serial connection with an oddball baudrate, so you should just be able to set up a 31250 baud serial input (if you're using the Propeller and Spin, FullDuplexSerial.spin from the standard library is what you want) on the right pin and see the MIDI bytes coming in when you do things on the controller.
  • Check this entry in the OBEX:
    http://obex.parallax.com/object/387
    This is for the Propeller. You did not say which Processor you had in mind.
  • You could also type "MIDI" into the search box in the upper right of the forum software to see some more info.
  • Publison wrote: »
    perfect, thank you.
    i did search the forum but wanted a proven working version.
  • BTW, I would say welcome to the forums, but I see you joined in 2016.
  • Publison wrote: »
    thank you
