TM1637 Driver (Spin)
JonnyMac
Playing with the TM1638 caused me to try the '1637 as well. The attached demo code was tested on this display:
-- https://www.amazon.com/gp/product/B06WWN9Z6J
...but will work on 4-digit displays with decimal points. I don't know if it's a bad pcb design or I received a defective module, but the button input pins (9-pin header) do not work as expected; on one of the eight button inputs seems to be connected to the TM1637. In my button demo code I can see buttons 1-6 (onboard) and button 16; none of the others work. The TM1637 is designed to sense one-of-16 buttons.
Added a demo for the wr_buf() method.
I also added a clock demo to the code for 4-digit displays that are configured 00:00.
That's a interesting display. I will order one in the New Year and try you code. Thanks for the code.
https://medium.com/@circuit4us/write-spin-code-for-tm1637-and-tm1638-part-i-f5568d2fe05b
Those modules do seem awfully expensive for a simple 6-digit LED display + buttons though.
BTW, you wouldn't want to see my Tachyon code for it, it's not complicated enough to be proper code
Agreed, but there are plenty of people who don't mind waiting a month for a cheap module from Ebay.
I wrote the objects for the TM163x chips as material for a book on Spin programming that I am writing.
the code must be so small, that I could not find it in your latest dropbox ...
or my search is not working correctly
@MJB I'm working outside of my Dropbox and I also don't have a display to check it on although it is easy to check the timing. This TM1637 is weird and you would think that it could have been a lot easier to communicate with in terms of "commands". One of the reasons that also contribute to the code being so small is because I don't try to have all these named methods, I just treat it as a character I/O device rather than have special methods just for strings and decimal point is set automatically within the previous character etc. Buttons come back as make and break characters too. So it just treats the TM1637 the same as if it were a physical serial character device which means there is no change to the application code. Even so the application only has to select the device with "TM" and PRINT" Hello World" anyway (in 7-seg "characters"). Printing "12.34" results in the decimal point being set for the previous "2".
Remember we did something like this for a 7-seg display you had once.
Here is the simple write function in Tachyon which could be made much simpler again but this version tries to bear some similarity to Jon's code simply as a comparison. I like to see where Tachyon can be improved, and these little exercises are good for that.
Tachyon code ( needs an active TMDLY to slow it down )
Original C Code (seems to leave last data bit bit not floating when clock is low in prep for ack)
