Wifi examples
CapdiamontCapdiamont Posts: 204
edited 2019-12-08 - 18:59:46 in Learn with BlocklyProp
I'm going through the C Wifi examples in to Blocky. It took me a bit to figure out what was the Wifi Listen code. I currently have the Val from Micro Host done, except I can't connect to the terminal though Wifi, so I have the terminal blocks disabled. If it was a regular variable I changed the name to as in the original code. If there was a default variable name provided by a function, I kept that name. This is done in Blocky Solo. The html code probally should be updated. I used the html file from the c code. Nice thing is there is only one file to load in Blocky.
