Hey there. Fairly new to pbasic, but I need it for a project. I'm trying to make my counter increase 1 every time I press my pushbutton, but can't seem to get my head wrapped around the code. Can somebody lend me a fresh brain? Stamp bs2, pbasic 2.5
' suppose button is on p0, with pullup resistor to Vdd
' state machine logic, can be part of a loop executing other tasks.
oldstate VAR bit
newstate VAR bit
activestate VAR bit
oldstate = in0 ' initialize state
DO
newstate = in0
activestate = newstate ^ oldstate & newstate ' active when button is released to high level
oldstate = newstate
IF activestate THEN DEBUG "buttonup",CR
' do other tasks
LOOP
There are many ways to scan buttons depending on the goal. There is also the PBASIC BUTTON command, but that is total overkill unless you want the repeat function.
Hi, i'm beginner , therefor i can't understand some simple thing like push button Counter. my problem: in need to write a simple program, which one, counting the push button,wenn pressed and save it in one register for later. for example: if button pressed one time, led1 on. led 2&3 off. if button pressed two time, just led 2 on. led1&3 off if button pressed 3 time, just led3 on, led1&2 off and wenn pressed a gain, repeat it same. i founded this code:
int main() { int count=0; int old_pb=0; int new_pb; pb.mode(PullUp); wait(.001); while(1) { new_pb = pb; if ((new_pb==0) && (old_pb==1)) count++; myled4 = count & 0x01; myled3 = (count & 0x02)>>1; myled2 = (count & 0x04)>>2; myled = (count & 0x08)>>3; old_pb = new_pb;
You need what's called a "Finite State Machine". There's a very thorough article in the Wikipedia on this (<https://en.wikipedia.org/wiki/Finite-state_machine>. Each state becomes a loop with a specific label. The program does a GOTO another state when a button is pressed. You might have something like this:
state000:
led1 = 0 ' Set up LEDs for this "idle" state
led2 = 0
led3 = 0
if button1 = 1 then goto state001 ' If button pushed, go to next state
goto state000 ' otherwise, stay in this state
state001:
if button1 = 0 then goto state002 ' Make sure button is released
goto state001 ' Stay in this state until button released
state002:
led1 = 1 ' Set up LEDs for this state's action
led2 = 0
led3 = 0
if button1 = 1 then goto state003 ' If button pushed, go to next state
goto state002
state003:
if button1 = 0 then goto state004 ' Make sure button is released
goto state003
state004:
led1 = 0 ' Set up LEDs for this state's action
led2 = 1
led3 = 0
if button1 = 1 then goto state005 ' If button pushed, go to next state
goto state004
You can continue this for as many states as you need. You could have a second button that takes you back to state000 or whatever you want.
Happened on this thread by accident, but a good book on this (if it is still in print) is "Digital Logic and State Machine Design" by David J. Comer. If you are a student or interested in this topic, it is an excellent resource. Lots of ways to get it, but don't bother with amazon new, we can put up with a lot of flaws in used $8.00USD vs. $200USD new. Also recommend the paperback if you can find it "Realtime Programming: Neglected Topics" by Caxton C. Foster. Both can be found on google books and other sources.
You can also digitally borrow many books for free from openlibrary.org. I've had luck there with older technical books.
Look at page 79 of "What's a Microcontroller?".
https://www.parallax.com/sites/default/files/downloads/28123-Whats-a-Micro-v3.0.pdf
A reference:
http://emesystems.com/OLDSITE/BS2fsm.htm#counter
