High-side driver recommendation?
Mickster
Inductive load, typically 2A @24v DC.
These are pre-wired, hydraulic-valve solenoids that I would like to PWM instead of simply switching on and off, via the existing SSR.
Edit: What I do have is a bunch of those pre-built LMD18200 modules.....I wonder if one module could be used to drive coil A and coil B? When both coils are de-energised, the valve-spool springs to the center position and the oil flow is shut off. Energise coil A for flow in one direction and coil B for flow in the other direction.
The answer to the question is yes. Normally bidirectional motion in a DC motor is achieved by changing the direction of the average current to the two motor wires. In your case though, current flow direction is irrelevant. There is two solenoids instead.
You can common the solenoid coils to either GND (PNP) or +V (NPN). The LMD18200 doesn't care.
http://www.ti.com/lit/an/slva460/slva460.pdf gives a run down but it's all straight forward.
EDIT: Corrected term used
As it happens, I already have the setup shown in Fig 6. (illustration #2)...Just haven't tested it yet as I have more pressing issues...that's like having two SSRs in a package that costs ~£5 (eBay) but with more capabilities.
I am over the moon, however, because for all intents and purposes, I have this original $150 directional hydraulic valve, doing what would alternatively be a $2000 proportional valve does. Client is gobsmacked.
Would-be entrepreneurs: There is a marketable product, right here...Phil's PWM object and a bunch of cheapie valves can save many a machine manufacturer a fortune, even with a handsome markup.
