Problem with the Badge WX LED's — Parallax Forums
Dear all,
I am quite new to BlocklyProp and am programming the Badge WX. When I try to address LED 1 to blue, all four of the LED's are switched on bright white. I am able to address LED's 2 ,3 and 4 in the expected way.
The code is below and attached. Any help much appreciated
// ------ Libraries and Definitions ------
#include "simpletools.h"
#include "badgewxtools.h"
#include "ws2812.h"
#define RGB_COUNT 4
// ------ Global Variables and Objects ------
ws2812 *ws2812b;
int RGBleds[4];
// ------ Main Program ------
int main() {
  badge_setup();
  ws2812b = ws2812b_open();
  // Allow the Badge WX to be programmed over WiFi
  high(17);
  RGBleds[constrainInt(1, 1, RGB_COUNT) - 1] = 0x0000FF;
  ws2812_set(ws2812b, RGB_PIN, RGBleds, RGB_COUNT);
430 x 203 - 15K
  • Works fine on my Badge.
    Maybe something wrong with LED 1 on your badge.
  • I experienced similar RGB addressing frustrations where I couldn't light the 4th light on my BlocklyProp Badge WX. I think it stemmed from me having one offending "RGB-LED set" blocks with an LED number of 0. I was thinking 0,1,2,3 not 1,2,3,4. It seemed like the compiler did some min max math and limited the last LED based on starting at 0.
