P2 Pull-up detection — Parallax Forums
I have been looking at the pullup detection in the ROM.
This code below gives the time for the pullup to pull the I/O pin back high is approximately as follows.
Note that I was adjusting the code, and because of the low clock counts, any moving of instructions affects the results. Also, at the lower frequencies the timing differences between outputting a pin and reading a pin has a more pronounced effect.
I would be interested to see what others might find.
clockfreq    5K pu      10K pu      15K pu
 20 MHz                 195ns
 25 MHz                 480ns?
 30 MHz                 396ns?
100 MHz      160ns      270ns       300ns
150 MHz      130ns      210ns       340ns
200 MHz                 195ns
300 MHz                 180ns
And the test code section of interest...
' try pullup/pulldown testing...
                drvl    #test_pin               'drive pin low
                waitx   ##us*1+2                'wait >1us
                modcz   _set,_set         wcz
                setpat  mask,val                ' sets flag when (INB & D)==S c=1,z=1
                fltl    #test_pin               'float pin
                getct   t1                      ' time
                waitpat                         ' wait for pin high
                getct   t2                      ' time
Warning: we cannot use this in the ROM because if there is no pullup then this code will wait forever.
