Bean, good morning...I am working with your I2C commands, and I am wondering if your can define the following for me with a little more detail. Again, I am trying to make the HMC6352 compass module work....with PROPBASIC
1. what is the ACKBITVALUE
2. what is the ACKBITVAR
3. and, I cannot seem to put more then "one" GOSUB in a DO/LOOP, with getting the error MESSAGE of "SUN OR FUNCTION CANNOT BE NESTED". In other words, one GOSUB in a loop will work, but two or more GOSUB's will not....
4. Where should I put the I2SPEED command to slow down the PROP...
1. ACKBITVALUE is the ack bit value that you want to send to the slave (0 or 1). Normally it is 0.
2. ACKBITVAR is a variable that receives the ack bit from the slave (0 or 1). Again normally it is 0.
3. You do not need GOSUB, just put the subroutine name. You are probably using SUB when you are calling. Don't do that...
4. If you use the built-in I2C commands they will run at the proper speed.
Looking at the datasheet you just send a "A" then wait a bit and read back two bytes.
Not having any success getting the HMC6352 working with I2C and PROPBASIC. Have tried several "angles and adjustments" to the code, with no joy...below is the code that I have been playing with.
DEVICE P8X32A, XTAL1, PLL8X
XIN 5_000_000
'========CONSTANTS============
baud2 CON "T115200"
HMC6352_READ CON $43
HMC6352_WRITE CON $42
GET_HEADING_command CON $41
'========[PIN ASSIGNMENTS]==========
'Assignments of pin go in each COG that is using that pin..
HMC6352_data PIN 3
HMC6352_clk PIN 4
'========[VARIABLES]===========================
valueSTR2 HUB string (3)
valueSTR HUB string (3)
I2C_DATA VAR LONG
rawHeading1 VAR LONG
rawHeading2 VAR LONG
rawHeadingTOT VAR LONG
ACKbitVar VAR LONG
PROGRAM Start 'this is running in COG 0
Start:
DO
' I2CSPEED .5'''''''multipier
I2CSTART HMC6352_data, HMC6352_clk
pause 10
I2C_DATA = HMC6352_WRITE
I2CWRITE HMC6352_data, HMC6352_clk, I2C_DATA
pause 10
I2C_DATA = GET_HEADING_command
pause 10
I2CSTOP HMC6352_data, HMC6352_clk
PAUSE 10
pause 10
I2C_DATA = HMC6352_READ
PAUSE 10 ' Give the HMC6352 time to calculate the rawHeading
I2CREAD HMC6352_data, HMC6352_clk, I2C_DATA, 0'''ackbitvalue'''''''SDAPin, SCLPin, var, ackbitvalue
pause 10
rawHeading1 = I2C_DATA 'HIGHBYTE Read in the high byte
valueSTR2 = STR rawHeading1,3,5
SEROUT 30, baud2, valueSTR2
SEROUT 30, baud2, 10
SEROUT 30, baud2, 13
I2CREAD HMC6352_data, HMC6352_clk,I2C_DATA, 0'''ackbitvalue'''''''SDAPin, SCLPin, var, ackbitvalue
pause 10
rawHeading2 = I2C_DATA 'LOWBYTE Read in the low byte
valueSTR = STR rawHeading2, 3,5
PAUSE 100
LOOP
END
I would like to add that I do know that the MC6352 that I am using is good, as it runs perfect on the BS2. The above code loads with no errors, and the "screen output" only shows a "2" and then a "208", with no change when the HMC6352 is rotated.
DEVICE P8X32A, XTAL1, PLL16X
FREQ 80_000_000
baud2 CON "T115200"
HMC6352_data PIN 3
HMC6352_clk PIN 4
valueSTR2 HUB string(4)
valueSTR HUB string(4)
Start:
DO
I2CWRITE HMC6352_data, HMC6352_clk, HMC6352_WRITE
I2CWRITE HMC6352_data, HMC6352_clk, GET_HEADING_command
I2CWRITE HMC6352_data, HMC6352_clk, HMC6352_READ
I2CREAD HMC6352_data, HMC6352_clk, rawHeading1, 0 'HIGHBYTE Read in the high byte
I2CREAD HMC6352_data, HMC6352_clk, rawHeading2, 1 'LOWBYTE Read in the low byte
valueSTR2 = STR rawHeading1, 3
PAUSE 100
LOOP
END
Sorry Bean, and thank you for your input, but all I get is the same thing....rawHeading1 = 255 and rawHeading2 = 255. I will keep snooping around...DennO
Do you have any examples of code..
Thank you...DennO
I2CStart
I2CWrite $42
I2CWrite 65
I2CStop
PAUSE 10
I2CStart
I2CWrite $43
I2CRead
I2CRead
I2CStop
Bean
ANybody, any thoughts...DennO
Bean
