Forum Update - Announcement about May 10th, 2018 update and your password.
Help with setting up environment
I prefer to use Visual Studio Code for my smaller projects.
It's been a while since I was coding with the Propeller so I've forgotten what tools I need.
What I'd like to do is create my own build system that can compile, run and upload the bin file to the Propeller. All from VS Code.
I assume I will need some command line applications for that. So that being said, what are the tools I need to run in order to do that?
IIRC, was it called OpenSpin or something like that?
Thanks!
